It is currently Sat Nov 21, 2026 3:42 pm
 Post subject: spark on valve cover
PostPosted: Fri Nov 11, 2005 5:02 pm
tonight i rerouted my fuel line so that it goes over the valve cover and uses fuel injection hose, fuel filter behind the alternator. went great, but then i started the car and was looking to check for leaks and out of the corner of my eye saw a flash. so i stared where it had been but saw nothing. then it happened again, right in front of the oil breather cap on the valve cover.
there are two electrical connections on the manifold there, close to the no 5 slot. my car is a 1975 dart, auto trans. i could not get the spark to replicate after that and drove the car without any trouble for 20 minutes. does anyone have any idea what it could be?
God took you away, then brought you back to me.
