| new distributor install https://slantsix.org/forum/viewtopic.php?t=14948 |
| Author: | Dustenn89 [ Mon Nov 07, 2005 2:28 pm ] |
| Post subject: | new distributor install |
well dad was trying to help me out the other day and pull my distributor for me. But what he didnt do was set it at tdc. now i have a new distributor but i dont know how to put it back in. can someone go through the steps of installing a distributor in a 225 dart swinger and how to get it to tdc with minimal mechanic skills. appreciated, Dustin |
| Author: | Pierre [ Mon Nov 07, 2005 2:56 pm ] |
You can do a search for "setting tdc" or "timing" and you'll get quite a few hits. Long version condensed: remove #1 spark plug. Bump engine over little by little with your finger in the plug hole. Wait until you feel pressure, then the next bump you feel suction stop. (Open the oil fill hole and make sure the #1 intake/exhaust rockers are loose, so you know your on compression stroke). Then put distributor in so rotor is facing the #1 spark plug wire on the cap. This will get you close enough to start the car then you can fine tune. You may have to remove the distributor and turn it one tooth either way dependign on how lcose you got to tdc with your finger. |
| Author: | 75dartcustom [ Wed Nov 09, 2005 6:16 pm ] |
first some info from SSDan: "Remove the frontmost spark plug. Get a long straight wire (like the bottom straight section of a wire coat hanger). Make sure the wire is longer than 8", and place it into the spark plug hole. Jiggle it around so you are sure it is touching the top of the piston. Rotate the engine by hand (using the fan and belt) or by bumping the starter motor. You will see the wire follow the piston down and up. When the wire reaches the top of its travel, the piston has also reached the top of its travel. There are two TDCs for each cylinder -- find the one that has the transverse notch in the crankshaft pulley is right at (or at least near) the "0" mark on your timing tab (that "piece of metal with a hole and one or two marks" you found). That said, the only reason you should have to worry about finding TDC before you put the distributor in, is if you rotated the engine while the distributor was out. If you didn't do that, then just put the distributor back in the engine so that the rotor is pointing the same way it was before you took out the distributor." I had a different experience when I pulled my dist. Everyone kept telling me, yeah just use the bolt on the pulley. all i found was a hole in the center of it. but there are also 6 holes around the edge so i made my own tool to turn the engine. i got some black pipe, 1/2' in diameter. run a 90 to a 2 1/2" nipple to a tee to a 12" section of pipe. put close nipples in the 90 and the tee. the close nipples fit in the holes around the perimeter of the pulley and the 12" pipe is your lever. i didn't need any extra leverage but if you do just grab a longer section of 1" pipe. its custom man, and very cheap. i found when i bumped the starter the pulley only stopped at 1 5 and 9 on the clock. Remember, the piston comes to the top of the cylinder on the compression and exhaust stroke. If the engine won't start, rotate it around 180 degrees. You will actually turn the wheel 2 full rotations. One to get the piston to the bottom of the cylinder, and then once again to get it to the top. When you have the engine in the right spot, place the rotor so it is right before or after the no 1 spark wire. I forget which way but when you push in the gears of the dist the rotor moves slightly. Just push it in, look at the way the rotor moves, then you can remove it and place it properly so it will end up in the right spot when the gears mesh. Then put the cap back on the dist, check all plug wire connections, put the battery cable back on and turn her over. Good luck and let us know if things don't go according to plan. |
