It is currently Sat Nov 21, 2026 11:58 pm
 Post subject: head compatibility
PostPosted: Wed Nov 09, 2005 9:17 am
I am considering buying a rebuilt head i see in the parts for sale area. Its off a 1965 225 but its been totally redone..any problems using it on a 1964 170?..they want more to rebuild mine than the one i can buy! including shipping..thanks for the info guys
PostPosted: Wed Nov 09, 2005 9:33 am
Car Model: 1962 Lancer 770
nope should be no problem. I put a 67 head on my 62, and the only problem I had was my 62 temp sensor had a larger diameter hole than the 67, so I had to get a new sensor.
If you've not had the head off before, you might want to take it to get it shaved down a little bit for better compression. The new gasket will be thicker than the original stock metal gasket, so you'll actually lose a little compression if you don't take a little off when you put the felpro gasket on.
MJ
PostPosted: Sun Nov 13, 2005 5:49 pm
thanks..i think the head has already been shaved..i thought someone said the rocker arms were different on the 170 but i might just be hallucinating *L..thanks again
PostPosted: Mon Nov 14, 2005 3:48 am
65 head for a 225 is fully compatable with a 64 170 engine. The pushrods for a 170 are shorter, then the 225 pushrods, due to the 170 block being shorter then the 225 block.
 Post subject: head
PostPosted: Mon Nov 14, 2005 12:03 pm
thanks Charlie..glad to see another floridian in here
