It is currently Fri Nov 20, 2026 2:28 pm
 Post subject: exhaust noises
PostPosted: Wed Nov 09, 2005 8:51 pm
sounds like a vacuum leak to me... Id check the play in the throttle shaft. My van does the same thing, and the throttle shaft bore is worn badly. Spray some carb cleaner around the throttle shaft at idle (leave air cleaner on) and see if idle RPM changes, or if miss changes. If so, its carb time! Just my 2¢ worth!
1953 Plymouth Belvedere, 1979 Dodge B-100 Van
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 5 guests
