It is currently Fri Nov 20, 2026 6:26 am
 Post subject: Erson cam?
PostPosted: Wed Nov 09, 2005 6:51 am
Has anyone used one of these cams from Summit Racing?
I am in the process of building a dedicated drag motor and found that they offer this cam with a .510 lift.
Next question would be if I could use it with .090 off of the head without piston clearance problems?
PostPosted: Wed Nov 09, 2005 7:06 am
I haven't used that, but looks like nice specs. You should use 9.5:1 comp minimum. 0.090" (or even 0.140") off the head will give no clearance problems with that cam in a 225.
PostPosted: Wed Nov 09, 2005 8:14 am
Thanks, Lou. I had thought about taking .100 off the head, but was going to be safe with .090.
PostPosted: Wed Nov 09, 2005 8:28 am
Hey, Robert. Good to see you back. Is that for the 66 Valiant? How is the car coming? I was going to give you a holler, but misplaced your e-mail address.
PostPosted: Wed Nov 09, 2005 8:53 am
No Charlie, the 66 found a new home in Jacksonville.
This is for a rail that I am building for a new type of class racing an internet group has started.
It has to be pre 62 vintage type. Motors, carbs, ignition has to be from that era.
One of the cars that is racing this class is a 261 GMC, running twin carbs with a glide tranny behind it and he is turning low 13's at this time. He has run a 12.99 with it. The motor is basically stock and the cars are weighing in around 1300 pounds.
Hopefully I can get the 225 to turn some of these low times. There are a couple of flatheads running, but they are in the 13's.
This is a heads up class, so the first one there is the winner.
I will try and email you later on this month and you can get my address again.
PostPosted: Wed Nov 09, 2005 10:01 am
Robert,
If you are really going to race, I'd do a combo - 0.100 off the block deck and 0.080" off the head. Or, 0.120" off the head or block would work safely. You'll be around 10.2-11:1 and I bet valve/piston will still be fine with that cam.
Keep us posted...
PostPosted: Wed Nov 09, 2005 10:09 am
Lou, I will definitely be doing this. I'll probably only take .100 off of the head as the block is already built except for the cam and timing gears.
One other limiting factor I forgot to mention, I can only run 6" bias ply tires in this class. I can't get so much hp that I spin the tires off the line.
I will be running a standard transmission and that is going to hurt a little bit.
Users browsing this forum: Bing [Bot] and 12 guests
