Motor Mount Replacement
https://slantsix.org/forum/viewtopic.php?t=14973
Author:  vynn3 [ Wed Nov 09, 2005 10:40 am ]
Post subject:  Motor Mount Replacement
Lost a motor mount on the way home from work last night (and I mean LOST — the alternator is resting against the passenger inner fender!). Replacement seems pretty straighforward, but the only time I've done it was on a V8 when the engine was out of the car. Any tips or tricks that would ease/quicken the process? I don't have a cherry-picker — can I do this job with a floor jack? As usual, thanks a bunch for your insight!
VM
Author:  mcnoople [ Wed Nov 09, 2005 10:58 am ]
On a slant if it is the drivers mount simple with a floor jack and a block of wood. Pass side can be a little tight fitting but doable. It really comes down to what kinda car it is in.
Author:  vynn3 [ Thu Nov 10, 2005 5:35 am ]
Sorry, I should know better by now. '72 Swinger, automatic. I'll be replacing both while I'm at it, but it's definitely the passenger side that failed.
VM
