| Q. 904 push button / column shift trans swap.... https://slantsix.org/forum/viewtopic.php?t=14977 |
| Author: | steve93101 [ Wed Nov 09, 2005 2:51 pm ] |
| Post subject: | Q. 904 push button / column shift trans swap.... |
I have a 1964 Dart with push button shift 904 trans. Trans (rear pump) is bad. I have a "donor" car 1965 Plymouth Valiant with a one year old rebuilt trans. The Valiant is a column shift. Any problems getting the push button cable shift mated to the column shift trans ? Thanks ! |
| Author: | SlantSixDan [ Wed Nov 09, 2005 3:12 pm ] |
Yep, you can use a '65 trans with minor modifications. See threads Here and Here. |
| Author: | Charrlie_S [ Wed Nov 09, 2005 4:42 pm ] |
Just install the valve body from the 64 PB trans in the 65 column shift trans. I would also swap out the speedo gear on the end of the cable, in case they are different ratios. |
| Author: | slantvaliant [ Wed Nov 09, 2005 4:50 pm ] |
Related info if you can't rebuild your cable-shift transmission, or find a replacement: Imperial Services can make pushbutton and '65 console or column shifters work with '66-up 904 transmissions. http://www.imperialservices.net/Imperia ... 0Parts.htm Scroll about halfway down. I'd prefer to keep my cable shift transmission, but it's nice to have an option. |
| Author: | 65 dartman [ Wed Nov 09, 2005 5:33 pm ] |
I have both console and column shift adapter kits from Imperial Services and both are first class all the way. |
| Author: | SlantSixDan [ Wed Nov 09, 2005 5:35 pm ] |
I've heard good things about Imperial Services' stuff. However, in three years of intermittent attempts, they have never returned an e-mail I've sent them, and I've never been able to get them on the phone. Eventually I just gave up. Have they got their shìt together now? |
