battery
https://slantsix.org/forum/viewtopic.php?t=14978
Author:  Matadem [ Wed Nov 09, 2005 3:33 pm ]
Post subject:  battery
I have a new ac delco battery 650 cranking amp. but this still seems weak
or my starter is going bad
would it hurt if I put a bigger one? 800 cranking ampere?or more?
I also going to get one of those mini starters
Author:  emsvitil [ Wed Nov 09, 2005 3:42 pm ]
A new 650 should be more than enough.
On the off case it's the battery, swap with another car to see what happens (other car's battery in this one, 650 in other car)
Check your battery cables
Check your grounds
Check for voltage drop:
positive terminal
starter soleniod
starter terminal
starter case
Author:  SlantSixDan [ Wed Nov 09, 2005 5:34 pm ]
Post subject:  Re: battery
I have a new ac delco battery 650 cranking amp. but this still seems weak or my starter is going bad
What exactly is the symptom you're getting? 650cca is far more battery than these cars came with new, and it's very much more than is necessary.
Author:  Dart270 [ Wed Nov 09, 2005 7:50 pm ]
In any case, get a mini starter and it will make you happy. I have a 280cca Odyssey dry cell battery (15lbs) in the trunk of my Valiant and it starts great every time.
