| 1920 Interchangability https://slantsix.org/forum/viewtopic.php?t=14980 |
| Author: | 75dartcustom [ Wed Nov 09, 2005 6:27 pm ] |
| Post subject: | 1920 Interchangability |
I have a 1975 225 with auto. trans. and a Holley 1945 and I want a new carb. Carter BBS seem hard to come by but 2 Holley 1920's have come up on ebay both well priced. One is model 1920 R4656A which is for a 1971 225 with auto trans. The second is model 1920 R6594A for a 1973 with auto trans. Both have the same bore as my carb. However the venturi's are different. Will either of these work for my vehicle? I will also need an electric choke, correct? |
| Author: | SlantSixDan [ Wed Nov 09, 2005 6:53 pm ] |
The '73 carb will have more of your '75 hookups. |
| Author: | 75dartcustom [ Wed Nov 09, 2005 8:06 pm ] |
will it offer improved driveability for my vehicle when compared with the 1945? and will it require an electric choke? there is a 75-76 electric choke on sale also on ebay for $15. |
| Author: | SlantSixDan [ Wed Nov 09, 2005 8:20 pm ] |
Quote: will it offer improved driveability for my vehicle when compared with the 1945?
The 1920 is a better design than the 1945, but there are ways in which 1920s deteriorate irreversibly after a few decades, and a carb in good shape is better than a carb in bad shape. I can't see this eBay carb you're talking about, so I can't comment. Your '75 already has an electrically-heated choke, which isn't the same as an electric choke. Don't know much about the '75-'76 unit you see on eBay; can't see that, either!
| Author: | 75dartcustom [ Wed Nov 09, 2005 8:58 pm ] |
here is a picture of the electric choke: ![]() part no 9085 1920 would be sent to carb doctor |
| Author: | SlantSixDan [ Wed Nov 09, 2005 9:06 pm ] |
That choke won't work with a 1920. Arm's the wrong length and angled the wrong way at the end. Gee, if you're going to send a carb to the OCD, you should take the time to find the carb you really want, which is a Carter BBS for a 1974 Dodge D100 pickup. Perhaps the OCD can help you find the carb. Or, maybe now's a good time to do a 2bbl swap? |
| Author: | 75dartcustom [ Wed Nov 09, 2005 9:32 pm ] |
would a 2 bbl require a different intake manifold? different throttle linkage? new choke assy? or is it link and go? |
| Author: | Jeb [ Thu Nov 10, 2005 7:20 am ] |
2-barrel would require different intake manifold, throttle linkage, kickdown linkage, and choke thermostat. |
| Author: | SlantSixDan [ Thu Nov 10, 2005 8:43 am ] |
Quote: would a 2 bbl require a different intake manifold? different throttle linkage? new choke assy? or is it link and go?
You'd need a 2bbl intake manifold, air cleaner, trans kickdown and throttle linkage assembly, shorter throttle cable and 2bbl choke (factory or new electric). And of course a well-built appropriate 2bbl carb. The upgrade is very much worthwhile on a car like yours. Driveability and performance improve considerably, and depending on your driving style, fuel mileage isn't affected significantly. |
