| exhaust noises https://slantsix.org/forum/viewtopic.php?t=14981 |
| Author: | 53plym [ Wed Nov 09, 2005 8:51 pm ] |
| Post subject: | exhaust noises |
sounds like a vacuum leak to me... Id check the play in the throttle shaft. My van does the same thing, and the throttle shaft bore is worn badly. Spray some carb cleaner around the throttle shaft at idle (leave air cleaner on) and see if idle RPM changes, or if miss changes. If so, its carb time! Just my 2¢ worth! |
