It is currently Fri Nov 20, 2026 10:06 pm
 Post subject: Water in the Oil Pan
PostPosted: Mon Nov 07, 2005 1:53 pm
This is a new one for me. A local machine shop rebuilt a sl6 about a year ago. I purchased for my 64 Valiant. Usual stuff so far. Came back today and had to refill the raditor again before starting. Started up fine until about 5 mintes of running motor. Knock started, radiator empty and the oil pan full of water/antifreeze. I know about the cracked block / head gasket stuff as a possible problem. My question is what would make this use so much water so soon? They overlooked the oil gallery plug in the back and i am wondering if they missed something else? Another oil plug? A problem around the water pump?
PostPosted: Tue Nov 08, 2005 2:11 pm
wow, that sounds like a ton of freeze if it made it all the way into the pan.
I would definitely pull the head and do a very thorough inspection. if you have the time to yank the motor I would do that to inspect it from the crank up- its sound like you'll have to yank it anyway.
PostPosted: Tue Nov 08, 2005 2:47 pm
hang on a second, you start pulling that motor apart and you can forget about going back to the rebuilder. Your warranty may already be dead and gone but you should still have them take a look at it, to rub their nose in it. They may still work with you to resolve the matter to your satisfaction.
PostPosted: Tue Nov 08, 2005 4:05 pm
Other than a crack the only way water and oil can mix on a slant is a bad/wrong/bad gasket. Since the radiator isn't full of oiled milkshake you can prolly assume that it isn't a head gasket leak at the oil passage but it could a leak at the coolant passage. I agree you should have the machine shop see it before you take anything off. That's some bad luck hope you get it straightned out and keep us posted.
PostPosted: Wed Nov 09, 2005 11:15 am
According to the machine shop, all thier blocks are magnafluxed before machineing. All of the head gaskets are same per them. They said to bring in oil sample to analyze. It looks like a milkshake so it shouldn't take long to do that. By the way [/b]they had to go back and machine the flex plate to a larger size. About a 1/4". So i am not even sure it is the same engine that was brought in to them.
I am about to weeks away from working on it again and it's killing me to wait to find out what happened.
PostPosted: Wed Nov 09, 2005 1:17 pm
The only reason they would have to machine the flexplate is too use the later (68+?) crankshaft that had a larger hub in the back. If you have milkshake in the coolant it almost has to be a pressurized oil leak. I would be looking at the head gasket but they all interchange assuming you don't have alum block.
PostPosted: Wed Nov 09, 2005 5:54 pm
Whats that again about the larger crank diameter for later engines? I checked the block casting number and it's for a 62-67 with a forged crank?
PostPosted: Thu Nov 10, 2005 6:55 am
Its been a while since I dealt with it but if my memory serves me right the hub that the flex plate/flywheel rides on on the back of the crank changed in 1968. It went to a larger diameter. The forged cranks interchange with each other, the cast cranks use different rod bearing than the forged cranks. I could be wrong on all of this my memory gets real fuzzy on stuff that I rarely see. I usually keep parts together and don't do any mix and match between years.
