| Engine chugs uphill? https://slantsix.org/forum/viewtopic.php?t=14987 |
| Author: | JohnnyDees [ Thu Nov 10, 2005 9:19 am ] |
| Post subject: | Engine chugs uphill? |
Weird problem with my 66 225. The acr is a 66 dart with a 4spd and od. 1 barrel carb stock motor. The car surges when running uphill only. on flat,downhill and slight inclines its fine. This happens no matter how full the tank is. It has a new sending unit with sock put in after the start of the problem. |
| Author: | mcnoople [ Thu Nov 10, 2005 10:36 am ] |
All speeds or only at certain rpms. Remember with a manual sometimes you do have to downshift. Although I would suspect 3.55 gear should able to overcome the low rpm lug factor. |
| Author: | SlantSixDan [ Thu Nov 10, 2005 10:40 am ] |
Probably a carburetor problem; do you have a Carter BBS or Holley 1920? |
| Author: | KBB_of_TMC [ Thu Nov 10, 2005 11:21 am ] |
| Post subject: | chug |
Coils do wear out, go bad, and sometimes leak oil. In the latter case, it may arc internally when the orientation changes and the transformer oil exposes a weak spot. |
| Author: | JohnnyDees [ Tue Nov 15, 2005 2:38 pm ] |
The carb is a 1920. The coil is brand new. Although that doesn't always mean ists good nowadays |
| Author: | mrbillohnooo [ Tue Nov 15, 2005 4:28 pm ] |
| Post subject: | surging |
If ya have a points distributor, check the dwell, I had a similar problem, and a new set of points and condensor cured it...mine would surge when it was in a hard pull...just a suggestion.... Bill |
| Author: | SlantSixDan [ Tue Nov 15, 2005 4:56 pm ] |
Quote: The carb is a 1920.
Certainly check the ignition components others have mentioned here—the coil is not likely to be the problem—but this sounds to me like a problem with the power ("economizer") valve in your Holley 1920. A rebuild kit and a good, thorough cleaning (with special attention to the metering block) may fix it...or may not.
