It is currently Sat Nov 21, 2026 4:21 am
PostPosted: Mon Nov 07, 2005 9:20 am
I just tried to use the Crane Cams Degree wheel and found that it wouldn't mount to my crank at all. My crank has a 2.25" crank bolt and a 3/4" bolt, so no go there, and the harmonic balancer holes don't line up either. Is there a dgree wheel that can be used with a Slant Six?
bwhitejr
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
PostPosted: Thu Nov 10, 2005 12:27 pm
I Used a Mopar performance degree wheel, and a big bolt from a 318 harm. Balancer. I use washers to shim it - it dosent go over the cam snout but in front.
