It is currently Sat Nov 21, 2026 7:35 pm
 Post subject: fuel pump leak
PostPosted: Sat Nov 12, 2005 6:19 pm
in the process of rerouting my fuel line i sawed off the old metal line to ease its removal. however, i now have a leak. although it is difficult to see down in that area i think it is actually coming from the pump itself. (at the diaphragm area, the hose connections are dry) the line i installed looks dry best i can tell. does this jive with you all? also i have a 75 dart that was (thank god the door sticker is still there) manufactured in may of that year. advance told me that they made two fuel pumps that year, one for before august and one after. anyone know anything about that? seemed curious to me. they look the same, would the difference be in pressure?
God took you away, then brought you back to me.
PostPosted: Sat Nov 12, 2005 7:05 pm
Pressure spec is the same on all slant-6 pumps. Wow, never had to saw off a metal line to remove it easily, but then I never owned a '75, either, and a '75's engine bay is considerably more crowded than that of an earlier car.
If you've got a leak at the pump crimp, toss a new pump on.
Users browsing this forum: DuckDuckGo [Bot] and 4 guests
