It is currently Sat Nov 21, 2026 1:50 pm
PostPosted: Mon Nov 07, 2005 1:24 pm
I am looking for an elec vac advance distrib. to replace my lean burn dist. on an 81 pickup. I found one on ebay but the ad says it is for 71 and earlier. Does it really matter what year its for?? Will it work on my truck?? If not what years will work on an 81?? Thanks
81 1/2 Ton, 2 WD,225, 4 Sp With O/D
81 3/4 Ton, 4 WD, 360, 727
70 1 Ton, 4 WD, 225, 4 Sp
PostPosted: Mon Nov 07, 2005 3:29 pm
There were no 1971 and earlier electronic distributors, so the ad is in error. Why not post a link to the auction you saw (or just tell us the eBay item number) so we can look and tell you what it really is?
All slant-6 distributors fit all slant-6 engines.
By the way, wow, that's a lot of abbreviations! ("elec" instead of electronic, "vac" instead of vacuum, "distrib" and "dist" instead of distributor, etc.) Go ahead and type out the whole word—remember, this is a free site; we don't charge by the letter like some newspaper classifieds used to do (resulting in ads that looked like "77 cut sup ps/pb 350 a/t vgc"). Whole words make it a lot easier to read what you write.
PostPosted: Mon Nov 07, 2005 3:40 pm
Used to? Has Canadian media and advertising started a new trend that hasn't yet made it down here?
PostPosted: Mon Nov 07, 2005 5:35 pm
Are you for real? By-the-letter newspaper classified ads charges went away in Colorado, Oregon and Michigan (that I'm aware of, and I'm assuming most other markets) years ago, in favor of "8 days, 2 lines, 5 bucks" or "10 days, 3 lines, 9 bucks" or "3 lines, 12 bucks, we'll run it til it's sold" type of deals.
PostPosted: Mon Nov 07, 2005 9:00 pm
Hm; most of the papers I'm familiar with (smaller towns), as well as the one I work at, give you, say the first 20 words for a set price, and then $x after that. Maybe it's time for us to revise our policy...
PostPosted: Mon Nov 07, 2005 9:21 pm
Well, yours may well be the standard policy; the ones I quoted were the promo deals they were always running (and singing about on the radio, and shouting about from billboards...). I wish those jingles were less effective: "Call 8-2-5-2-5-2-5! The Denver Post FirstClassifieds! You'll sell it in ten or we'll run it again, in the POST!" That's easily 15 years old. The phone number was a tie-in for when they first dropped per-letter charges: 825-2525, you got 8 days with 2 lines for 5 bucks.
PostPosted: Tue Nov 08, 2005 7:04 am
Heres the link to the ebay ad I saw for a distributer
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... RK:MEWA:IT
PostPosted: Tue Nov 08, 2005 8:13 am
The should do exactly what your after. Just to clarify, that set-up is not from a 71 and earlier /6, but rather it's designed to update the earlier ones to standard electronic ignition. For one stop shopping, I'd say that's not a bad price, but if you are willing to scrounge and buy parts from seperate places, you might be able to get by a little bit cheaper.
PostPosted: Wed Nov 09, 2005 11:45 pm
Is this the correct distributor for a /6?
http://cgi.ebay.com/ebaymotors/ws/eBayI ... AMEWA%3AIT
And is this the complete set-up?
Is this different than the one that Mopar sells in the hot rod section?
Aside from the petronix, is there another alternative for elctonic ignition?
I know this is a lot of questions, but they all seem to be on topic.
Yeahbut
1967 D100 /225
Some of us catch on slow, and some of us don't.
PostPosted: Thu Nov 10, 2005 6:40 am
There's a lot out there. For the pickup, the easy bolt-in choices include the stock Mopar (VR sensor), Pertronix (uses a Hall effect sensor), and I think there's at least one Mallory distributor available too. Or, in some cases, you can use points to drive an aftermarket electronic ignition module. Still has a bit of wear, but since they don't have to carry a high current, wear on the points is a lot less.
Once you have a trigger, there is no shortage of ignition modules. The most commonly used ones are the various Mopar boxes, the GM HEI, and the MSD-6, but there's got to be at least a dozen others that may work.
And if you're truly adventureous, it is possible to put a toothed wheel on the crankshaft pulley and run a coil pack, removing the distributor entirely. I know of at least one slant six running an Electromotive crank triggered ignition, and it's also possible to use Ford EDIS-6 hardware.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Fri Nov 11, 2005 5:45 pm
Thaks for the insight. I think I'll keep it simple and use the Mopar Electronic Distributor, and maybe down the road add a MSD.
Yeahbut
1967 D100 /225
Users browsing this forum: Amazon [Bot], Google [Bot] and 8 guests
