It is currently Sat Nov 21, 2026 1:49 pm
 Post subject: Engine build-up
PostPosted: Sat Nov 05, 2005 9:04 am
Ok, I've decided it's probably time to start thinkin' about a replacement engine for the old beast ('82 D-150). Rather than rebuild what's currently in it, I'd like to just build a new and keep driving it until it's ready to go in. I’ve seen a fair bit posted on some of these topics, but this is my first build-up, so I'd like some re-assurance. Also, most people are building for cars. I’m not sure how/if I should compensate for the extra weight of my truck.
I'm going for a medium performance build, though it will probably never see the strip. I just want something fun and peppy to drive around town (and to take on the 300 mile trip home once in a while). I’m assuming I should build for torque rather than top-end. Right now I'm thinking the Compcams 264S and a Holley 2300 on the intake side. At some point in the future I'd like to transition to a 4 barrel or EFI. I don't really access to the tools to do any custom exhaust, so it's gonna have to stay w/ the stock exhaust mani, for the time being.
Edit- The rear has 3.2? gears in it; I'm planning on keeping it, although replacing the bearings and seals.
As far as head work goes, my uncle lives about an hour away, but he has a full automotive machine shop. Definitely doing some porting, and I'm contemplating oversized valves (the oversized SI’s?), and possibly shaving the head a bit. I want to be able to run 87 octane though, and would like to have the option of forced induction at some point in the future. Would I be best off not shaving the head? In addition, what year range of head should I look for? I don’t' know the advantages/differences between them.
Finally, what about the block? I definitely have to keep the large pocket crank so that it mates up w/ my tranny. Aside from that, is it really worth my time and money to find a forged crank engine, or is a cast crank block usable? I don't intend to bore it out any, and probably wont' be using anything too special when it comes to pistons. I have a somewhat arbitrary limit of $20 per piston; can I get anything in that price range that is worth my money?
-Chris
PostPosted: Sat Nov 05, 2005 1:33 pm
Medium performance for a truck............
minor head work.... just clean up the ports and cc match chambers.
shoot for about 9.0:1 compression ratio... should be fine on regular with extra weight. The slightly oversized values you can get (1.70/1.44???) should work good. Try to get some squish into the combustion chamber (deck/head shaving); helps with power and pinging
going for torque is good, look into the archives on custom cams. I think gearhead has some good ideas. If the 82 has the 244 degree cam, you could just stay with that.
port match manifolds.
For a 2bbl carb, I'd look into a primary/secondary setup.
clean up the stock exhaust manifold, then have at least a 2 1/4" exhaust pipe. Dutra duals would be an upgrade on this, headers not necessary.
For medium duty, cast crank is good. I'd overbore just enough to clean things up with corresponding piston. Don't need forged piston, I'd look into hypertectic ones.
PostPosted: Fri Nov 11, 2005 8:37 am
Ok, I found a motor from a '78 Volare w/ the super six setup locally for just over $100. I think I'll be ok w/ the cast crank; should there any problems with using this as a starting point for a build-up?
Users browsing this forum: Amazon [Bot], Google [Bot] and 7 guests
