It is currently Sat Nov 21, 2026 4:54 pm
PostPosted: Sun Oct 23, 2005 6:06 pm
If I convert a 1963 225 cu inch engine to hydraulic lifters, will the original valve cover clear the rockers?
I notice that original hydraulic lifter engines use a valve cover that is squared off and not canted like early valve covers. Does this signal clearance problems upon conversion? If so, does anyone have any recommendation for solving the clearance problems?
If I've read the prior posts on this board correctly, all that's necessary for the conversion is the hydraulic cam, lifters, pushrods and rocker arm assembly. Am I missing anything?
Would the conversion benefit from the high output oil pump?
Any experience with the Clifford 254 Duration Hydraulic Camshaft?
TIA
--Walt Jackson
--1962 Dodge Dart GT convertible
PostPosted: Sun Oct 23, 2005 7:44 pm
Good question. Don't know. Can't imagine wanting to do such a conversion!
A way to feed enough oil to the hydro lifters. Grooving the rearmost cam journal can take care of this.
A regular oil pump in good condition, in an engine in good condition, should be adequate. Still can't imagine wanting to do this conversion, though.
No, but enough experience with Clifford's business practices not to care how any particular part they offer might work.
PostPosted: Mon Oct 24, 2005 7:49 am
Walter, The valve cover itself is a different shape to fit the hydraulic head. If you used a standard head, the standard cover should still work.
I would put the high output pump on just to make sure the rockers get enough oil. They pump the lifters up by sending the oil down the pushrods to them. Dan is right, the rear cam bearing has a groove in it on hydro motors. I tried to get a grooved bearing when I did my motor, but they appeared to be unavailable now.
No experiance with that particular Clifford. :shock:
PostPosted: Mon Oct 24, 2005 1:09 pm
Dennis, I don't know for sure, never worked on a hydro motor, but I think the groove in on the rear cam journal, not in the bearing. Can anyone confirm this, for sure?
PostPosted: Mon Oct 24, 2005 1:42 pm
Factory hydraulic slants use a different rear cam bearing.
The "groove the rear cam journal" thing is for retrofitting earlier engines while retaining the original-type cam bearings, which are compatible with the earlier engines.
PostPosted: Mon Oct 24, 2005 1:56 pm
During one of the cam/top end oiling discussions, I went to the Carquest warehouse and looked at a set of the late cam bearings. I was curious, to see if these could be used in the early engine to increase oil flow to the top end. The bearings I looked at did not have a groove in the rear bearing. Maybe it was boxed wrong, I will check again, next time I'm there.
PostPosted: Mon Oct 24, 2005 7:04 pm
I tried to get the grooved bearing when I did my motor. Car Quest had 2 different sets of bearings lised, and neither set had a groove. :shock:
IIRC, my Ultrdyne hydraulic cam does have a groove in the rear journal. :shock:
PostPosted: Tue Oct 25, 2005 3:49 pm
Had to go to the part warehouse, today. They had a stock replacement cam for a 82 D150, in stock. Took a look at it. It does have a full groove around the rear cam journal. The part number for the cam bearings, is different between the hyraulic cam and the solid cams. I also checked the cam bearing numbers and specs. The rear cam bearing is the same in both applications. The # 1,2,3 bearing are shorter for the hydro engine. At this time I don't know the reason for the difference in the length. Wether it is a cam issue, or a block issue.
PostPosted: Tue Oct 25, 2005 4:25 pm
SSRN National Champion
Im with Dan on this one what is your reason to convert to hydrulic lift cam and lifters. I would like to hear a good reason. Thanks Ron Parker :D
Bagel Went Boom I Go Zoom
 Post subject: A GOOD reason???
PostPosted: Tue Oct 25, 2005 9:54 pm
Well, if ya just wanna drive it and not worry about having to adjust the valvesMIGHT be a good reason. My personal experience adjusting slant valves is that it isn't all that difficult, and I'm something of a tinkerer anyway.
What I don't know is how long a proper valve adjustment is good for, and is there any difference in performance between hydraulic and solid valvetrains.
There will always be differing opinions, but ya know what they say about opinions: They're like rectal orfices - they're all different and they all stink, except mine! :roll:
PostPosted: Wed Oct 26, 2005 11:08 am
I have a Mopar Performance hydraulic cam and lifter kit. The rear journal of the camshaft has a groove.
Also refer to this service bulletin....
http://www.slantsix.org/forum/viewtopic ... ters#77015
Notice no mention of a different camshaft rear bearing. This is in 1978 model year however.
PostPosted: Wed Oct 26, 2005 4:40 pm
I can just give you the reason I am going to a hydro cam:
Just because :P
And it is in the wife´s car, and I don´t want to touch it, if I don´t have to :wink:
PostPosted: Sat Nov 12, 2005 7:57 am
Well, I guess it`s time to relate my recent experience with Clifford on just this matter.
Stay with solids, unless you enjoy headaches!!
Cliffords expertice must have died along with Jack Clifford. Those guys don`t know jack $#!+!! They will be happy to sell ya any of thier products, tho!
To thier credit, they did exchange the hyd cam & lifters for a solid one,with my only expense being shipping back to them. That DID cost me double, the address on thier website has not been updated, and they moved 12 weeks earlier, at that time! So the hyd cam made a round trip, and then back again :roll:
If ya gotta have hyd, buy an orig hyd engine to start with, much easier on the brain!
BTW, Summit carries brand new Offy alum valve cover at a decent price, and man, what a look!!
Bob
PostPosted: Sat Nov 12, 2005 8:38 am
So which cam did you ultimately end up with, and are you satisfied with it's performance?
Chris
Users browsing this forum: No registered users and 16 guests
