It is currently Sat Nov 21, 2026 6:53 pm
Post new topic  Reply to topic  [ 26 posts ]  Go to page 1 2 Next
 Post subject: swap /6 for 273
PostPosted: Thu Nov 10, 2005 9:17 pm
I am being told by my chevy buff friends that I can swap my /6 for a 273 without front suspension work only beef up the brakes. I dont think so but i am not sure. does someone know
James E. Faith
My First Ride built 14 years ago....still got it!
http://www.pctradepost.net/images/71.jpg
PostPosted: Thu Nov 10, 2005 9:34 pm
Suspension work? The most "suspension" work you'd have to do is swap torsion bars which takes all of an hour or two with the remover/installer tool. Probably be a good idea to do this while the engine is out anyway if you haven't replaced your bars in 30 or 40 years, plus they are relatively inexpensive. ~$130 in all sizes from Mopar Performance.
Try http://www.engine-swaps.com/ or www.moparts.org for more info on swaps to v8, most ppl here swap to /6 if anything.
Whether or not you need to swap the K-frame to put a V8 in place of the slant-6 depends on the year and model car you're working with. Stop listening to your Chevy-head friends; if they're Chevy-heads they don't know what the héll they're talking about with regards to your Mopar.
If you put in a V8, your brakes need to get larger. So do your torsion bars. So does your radiator. If it's a healthy V8, so does your rear axle. And 6-cylinder transmission won't bolt to the V8.
PostPosted: Fri Nov 11, 2005 3:29 am
Car Model: 1964 Dodge Polara 2 Dr HT /6 3spd man
What is your goal? If you do some research on this sight you can find helpful information regarding relativly inexpensive upgrades. By the way nice Nova!
edit
PostPosted: Fri Nov 11, 2005 3:30 am
edit
PostPosted: Fri Nov 11, 2005 3:32 am
Sorry folks, looks like I need a inexpensive computer upgrade!! :lol:
PostPosted: Fri Nov 11, 2005 3:43 am
Lift the mouse and drive new computer under it. :wink:
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Fri Nov 11, 2005 5:08 am
efaith-
murch is right, definitely a nice nova! but how did a slant get in it anyway? wouldn't it be easier to swap in a 283? :shock:
seriously, schumacher's mounts are very high quality and will do exactly what they say. just call and tell them everything you plan on doing and they will steer you straight. new torsion bars are almost a must. an old car may have had them changed out at some point. you may be able to look at the end in the rear anchor point and find the number to tell you what you have. they're probably covered with filth, but a can of brake clean and a rag should do it. if you have discs/dual circuit master cylinder already, i wouldn't worry too much about upgrading the brakes. just remember, any problems already in the front end will be exacerbated by adding weight to the front end turning a sloppy handling/braking car into an evil one.
-james
PostPosted: Fri Nov 11, 2005 5:53 am
And whether you want to swap torsion bars will depend on what use you have in mind for this car. Many V8-powered drag Mopars run Slant Six torsion bars to make the front end lift under hard acceleration and help put weight on the rear wheels.
On the other hand, for a street car with decent ride and handling, I'd have to say that the 0.870" bars that came with various smallblocks are about right for a slant six. And I'm starting to think I may actually want an even thicker set - without an engine swap.
Some of the upgrades that are recommended if you swap in a V8 are things you might end up doing with a hot slant six car anyway.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Fri Nov 11, 2005 7:49 am
The money spent switching to a 273 could be put into your Slant instead. You'd end up with a better running car when you're done too. Stock 273's are kinda wimpy. :shock:
PostPosted: Fri Nov 11, 2005 8:13 am
Why bother with a 273 when a 360 is virtually identical in external dimension? It probably doesn't weigh a lot more either. I curious though, how much more does a small block weigh over a 225?
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Fri Nov 11, 2005 8:37 am
Well, I found my own answer. The 225 weighs 475 lb, the small block 273, 318, and 340 weigh 525, and the 360 weighs 550. Given the power and sturdier construction of the 340 that would be my first choice though they are getting hard to find. I understand the a 340 block is available new from MoPar Performance but it's pricey.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Fri Nov 11, 2005 8:57 am
Why does everybody 'dis 273's? I've got 2 Darts, one with a slant and one with a 273. I like driving both for different reasons. The 273 is stock (2bbl) except for dual exhaust, and it's far from "wimpy" (it'll still beat the crap out of my modified slant), sounds great, and gets mileage comparable to the 225. I'd originally intended to build a 402 stroker for the slant car, but (maybe it's old age setting in) I've started to appreciate the efficiency of smaller engines, especially with gas prices being what they are. 273's have a lot in common with slants — no respect from the "bigger is better" mainstream crowd...
VM
PostPosted: Fri Nov 11, 2005 9:31 am
VM
Uhhhhhhhhh, because this is a Slant board. :shock:
