| bogging https://slantsix.org/forum/viewtopic.php?t=15017 |
| Author: | JDS [ Sun Nov 13, 2005 1:14 am ] |
| Post subject: | bogging |
i have an all stock 72 valiant. the engine was rebuilt in 2001, and i recently had the head squared while the intake and exhaust manifold were off due to some broken studs. the problem i am having is a serious off-idle hesitation and bog. if you roll on the throttle nice and slow(ah la old lady) there is no problems. but if you get on it, the engines cuts out then idles back up with a bogging down feeling, and the occasional intake back-fire, almost like the brakes are dragging. i have replaced the fuel pump, filter and rubber lines. new spark plugs, wires and dist cap. new points and coil. carb is also rebuilt, on when i got it, but has a light fuel leak at base, basically dampness. timing is set at TDC and valves are at .010 and .020 hot. has new factory spec cam and timing chain. other than getting a dud rebuilt H-1920, i am baffled, definetely losing this fight. anyone have any suggestions...maybe a rebuildable 1920 they wouldn't mind parting with.... |
| Author: | skraecken [ Sun Nov 13, 2005 1:18 am ] |
Quote: timing is set at TDC
8-15 btdc could be better.
| Author: | Eric W [ Sun Nov 13, 2005 2:11 am ] |
Quote: Quote: timing is set at TDC
8-15 btdc could be better.One other thing I'd like to suggest: Get electronic ignition. One of the most basic and best thing you can do with your slant. |
| Author: | SlantSixDan [ Sun Nov 13, 2005 8:17 am ] |
| Post subject: | Re: bogging |
Quote: i have an all stock 72 valiant. the engine was rebuilt in 2001, and i recently had the head squared while the intake and exhaust manifold were off due to some broken studs. the problem i am having is a serious off-idle hesitation and bog. if you roll on the throttle nice and slow(ah la old lady) there is no problems. but if you get on it, the engines cuts out then idles back up with a bogging down feeling, and the occasional intake back-fire
Prime suspects are a faulty accelerator pump or power ("economizer") valve in the carburetor, and late ignition timing. With the engine off and the air cleaner lid removed, peer down into the carburetor and operate the throttle linkage by hand. You should see a nice, solid shot of fuel ("Psst!") squirted into the centre of the carb throat every time you do this. If it's weak and piddly or not present, the accelerator pump isn't doing its job. Quote: carb is also rebuilt, on when i got it, but has a light fuel leak at base, basically dampness.
"Remanufactured" carburetors are, as a lot, garbage. Especially the Holley 1920s, which have a metering block that can just die and refuse to work.Quote: timing is set at TDC
As others have mentioned, this is too late (retarded), though I disagree that 15° BTDC would be a wise choice of setting with a stock '72 distributor. Start with 5° BTDC. Quote: other than getting a dud rebuilt H-1920
Very, very likely.Quote: maybe a rebuildable 1920 they wouldn't mind parting with....
No, but I have a new one... |
| Author: | JDS [ Sun Nov 13, 2005 11:26 am ] |
i bumped the timing to 5btdc, no change. i am new to the whole mopar world, i have been waist deep in AMC v8 powered jeeps, so i thought an inline with a one barrel would be fun to tinker with, and its kicking my ass. i noticed when the engine revs there is no gradual increase in the timing, it just jumps ahead 10 degrees, then jumps back. every AMC i have built i put DUI on it, and they have a nice smooth curve. I am wanting to put electric on it, but i want to keep it as stock looking as possible. what would be the best donor vehicle? and where can i just purchase a NOS unit and all the trimmings? if you use a new one do you have to replace the cam gear to allow them to break in together? i checked the accelerator pump before, and it squirts nice and strong. but i did notice that during operation the carb is drier, andis actually forming drops now once i shut it off and it sits a half hour or so. as for the points, i gapped them initially with a feeler gauge, then used a dwell meter to dial it in perfect.....anyone know where i can get a choke thermostat? this is a 72, but i put a NOS 74-on exhaust manifold on it |
| Author: | JDS [ Sun Nov 13, 2005 12:18 pm ] |
forgot to mention it hates to start cold, i have to beg it to start for about 15min before it will even pop off. acording to my Chilton's, the choke thermostat is behaving itself, but it has seen better days and i would like to find a NOS to replace it |
| Author: | SlantSixDan [ Sun Nov 13, 2005 12:35 pm ] |
Go grab This better Carter carburetor off eBay. Either go through it yourself or send it to the Old Carb Doctor (800-945-CARB). You'll wind up happier than with your stock-type '72 Holley carb, and this particular Carter has all the fittings and linkage hookups to work with your existing setup. The stock '70-'72 style choke can make problems (leaks between the choke cup and the manifold, notably) but if the thermostat's working OK, the problem is, again, probably with the carburetor. The existing choke thermostat will hook up to that Carter. Dump the Chilton's book, they're garbage. Get a factory service manual. |
| Author: | JDS [ Sun Nov 13, 2005 1:35 pm ] |
i am running a later exhaust manifold, so i don't have the tub anymore, it is sealed to be usable with the supersix, i just kept the actual thermostat |
| Author: | SlantSixDan [ Sun Nov 13, 2005 2:02 pm ] |
Quote: i am running a later exhaust manifold, so i don't have the tub anymore, it is sealed to be usable with the supersix, i just kept the actual thermostat
Oh, no, that won't work very well. The '72 thermostat will bolt onto the later exhaust manifold, but it won't operate properly. If you're keeping the 1bbl setup, use a '73 choke thermostat or go to the Electric choke package.
| Author: | JDS [ Sun Nov 13, 2005 8:17 pm ] |
this is the story behind the car. it is a true survivor, zero, ZERO rust. all original documentation, dealer invoice. still has the original dealership license plate logo'd border. interior has two problems, driver and passenger seat belt female portion dosen't work, and on the drive home i had the front windows rolled down on the highway, big mistake. the headliner in the back just fell apart, it was immaculant, but the cotton is 35yrs old and just couldn't take the wind and gave out. it has 85,000 original miles. i am the second owner. the original owner put it up for sale when she lost her license when her eyesight gave out. a real old lady car. i want it to be a super clean, smooth running, dependable daily driver for my wife. she wants me to put a V8 in it but i like the underdog SL6. i just sold her 74 CJ5 with a 401 i built, so she misses the V8 rumble. i plan on buying a 2nd SL6 and building it up on the stand and when its all done swapping it out. i imagine this describes half the people on here, just wanted to help share what i plan for this car in the future. so any mod that would improve dependability and driveability would help |
