It is currently Sat Nov 21, 2026 9:10 pm
 Post subject: Cam shaft ideas
PostPosted: Thu Nov 10, 2005 12:21 am
Okay guys...
I am keeping my rust free original paint 70,000 mile hemi orange 70 swinger with it's slant in it and black guts... I just about have the interior finished...I rounded up a Am/Fm radio for it today and in the next couple of days I will have the interior finished...
I would love to get some info on basic upgrades for the slant...I have a 8 and 3/4 for it and Disk brakes...As well as a sway bar front suspension...I would like to maybe plane the head some and look for a better cam...And if someone was sick of their Offy or clifford research intake and header...
But I would be happy with planing the head a little adding a 2 bl carb...Dual exhausts and a better camshaft...I have a 323 sure grip for the car...So it would work a lot better just with the better gears....It has the infamous 276 ratio 7 and 1/4 in it now...
Any help with slight performance upgrades is appreciated...I do not need to break any speed records...Slight upgrades are welcomed...Dual exhaust and..Better cam and carb would probably make me pretty happy.
-Peter
PostPosted: Thu Nov 10, 2005 7:52 am
I am running a Super Six 2bbl, 3.23 gears 9.25CR, 2.25 exhaust with a Comp 264S cam. This como is very tractible and has lots of git.
I also installed bigger Chev valves but they are no more necessary than your dual exhaust.
 Post subject: Cam specs ..
PostPosted: Sun Nov 13, 2005 7:24 pm
Hiya ! Well the australian Valiant Pacer 225 which put out 175hp factory spec (and was still tracticable to drive) used a cam with the following timing: ~ lift: (both in/ex) .395" ~ duration:..inlet opens 12*btdc..inlet closes 52*abdc ..exhaust opens 50*bbdc ..exhaust closes 14*atdc
..Carby was 318-type Carter BBD-4300S (man) or BBD-4301S (auto) [throat bore 1.44"..venturi 1.062"] main jet no.120-310S ..metering rod 75x1752(man) or 75x1723(auto) ..metering rod-dia .024"/.022"(man) or .027"/.025"(auto) ..float level at float centres .25" ..choke unloader .250" (no.30 drill) ..idle mixture one turn out approx ..fast idle with screw on first step of cam ..choke setting 2 notches rich ..Good Luck! :D
ps ..fit a nice set of tuned headers to go with this set-up! 9.2:1 comp will give 155psi cyl pressures at 130rpm test
