| blues-reivisited https://slantsix.org/forum/viewtopic.php?t=15022 |
| Author: | 63gtcv [ Sun Nov 13, 2005 3:41 pm ] |
| Post subject: | blues-reivisited |
I posted about my 6mth. old oil pump going south on me. From the feedback I got from y'all, I decided to install a used pump from my 71 truck. When I removed the bad pump from the Duster the gear wasn't attached. I'm sure it is nice and safe way down in the bottom of the pan. Anyway, after installing the well used pump,I still had no pressure. I then primed the pump by filling it with oil. Bingo, good to go. Bearings sound rough, but not much worse than before. Now all I gotta do is return the pump without the gear to O'Reilly, you know, late at night. Thanks to all. Bart-63gtcv |
