It is currently Sun Nov 22, 2026 3:43 am
 Post subject: Engine chugs uphill?
PostPosted: Thu Nov 10, 2005 9:19 am
Car Model: 62 Lancer GT
Weird problem with my 66 225. The acr is a 66 dart with a 4spd and od. 1 barrel carb stock motor. The car surges when running uphill only. on flat,downhill and slight inclines its fine. This happens no matter how full the tank is. It has a new sending unit with sock put in after the start of the problem.
1966 Dart GT
4 spd. OD conversion
8 3/4 - 3.55 SG (Sold)
62 Lancer GT
B Body 8 3/4
PostPosted: Thu Nov 10, 2005 10:36 am
All speeds or only at certain rpms. Remember with a manual sometimes you do have to downshift. Although I would suspect 3.55 gear should able to overcome the low rpm lug factor.
PostPosted: Thu Nov 10, 2005 10:40 am
Probably a carburetor problem; do you have a Carter BBS or Holley 1920?
 Post subject: chug
PostPosted: Thu Nov 10, 2005 11:21 am
Coils do wear out, go bad, and sometimes leak oil. In the latter case, it may arc internally when the orientation changes and the transformer oil exposes a weak spot.
PostPosted: Tue Nov 15, 2005 2:38 pm
The carb is a 1920. The coil is brand new. Although that doesn't always mean ists good nowadays
1966 Dart GT
62 Lancer GT
B Body 8 3/4
 Post subject: surging
PostPosted: Tue Nov 15, 2005 4:28 pm
If ya have a points distributor, check the dwell, I had a similar problem, and a new set of points and condensor cured it...mine would surge when it was in a hard pull...just a suggestion....
Bill
If ya haven't been there, you just wouldn't understand.....
My friends and I spent a LOT of money in the eighties to get me this way!!!!
PostPosted: Tue Nov 15, 2005 4:56 pm
The carb is a 1920.
Certainly check the ignition components others have mentioned here—the coil is not likely to be the problem—but this sounds to me like a problem with the power ("economizer") valve in your Holley 1920. A rebuild kit and a good, thorough cleaning (with special attention to the metering block) may fix it...or may not.
Users browsing this forum: No registered users and 14 guests
