Going Super Six, starting this Sunday
https://slantsix.org/forum/viewtopic.php?t=15057
Author:  Avenger2040 [ Thu Nov 17, 2005 3:32 pm ]
Post subject:  Going Super Six, starting this Sunday
Yes, that´s it, finally found a two barrel intake, so the question is: Wich carb is the good one? any suggestions to get a good carb?
Author:  63gtcv [ Thu Nov 17, 2005 4:07 pm ]
Post subject:  super six-shooter
On my 63 Dart I used the Carter BBD. It came straight off of a 318 truck, no changes necessary. Good for me. P.S. Nice car. You're going to like the feel of the new set-up.
Author:  Avenger2040 [ Sat Nov 19, 2005 9:10 am ]
Thanks 63gtcv, I will go out and seek for a good Carter carb or Holley if I found one nice and cheap.
Author:  CStryker [ Sat Nov 19, 2005 6:53 pm ]
If you go with a Holley, you will have to also purchase an adapter plate. The Carter that originally came on it uses a smaller bolt pattern.
Author:  Avenger2040 [ Sat Nov 19, 2005 8:16 pm ]
ok, I will get a adapter plate, but any suggestion of a good carb to buy?
Author:  Rust collector [ Sun Nov 20, 2005 5:20 am ]
Carter bbd :P
There was that holley (2280???) which some people hate, but fits the manifold...
Or my personal favourite, the weber 38-38, but then you need an adapter again.
Author:  Avenger2040 [ Sun Nov 20, 2005 7:56 am ]
Ok, I will search for a good Carter BBD, thanks guys! I will keep you all inform from progress
Author:  75dartcustom [ Wed Dec 07, 2005 9:50 pm ]
whats the update on the super six?
