| Cams https://slantsix.org/forum/viewtopic.php?t=15062 |
| Author: | Irv83 [ Fri Nov 18, 2005 8:41 am ] |
| Post subject: | Cams |
Just a note to the ignorant, as I was until recently. In thinking about a cam for my 225, I imediately thought of Comp cams because of their advertising. Somewhere in the course of my reading, I found that RACER BROWN Cams have Mopar, Nisan, and BMW FACTORY PART NUMBERS. I'd sugest checking them out. Has anyone had experience with their cams ? Irv83 |
| Author: | Wild1_Robertson [ Sun Nov 20, 2005 12:56 am ] |
| Post subject: | racer brown cam |
personal experance was on a 426 max wedge I build using a Racer brown cam. no cam problems. |
| Author: | Slanted Opinion [ Sun Nov 20, 2005 4:04 am ] |
Years ago Mopar's Direct Connection catalog always used to include a couple of Racer Brown camshafts in the Slant Six performance section. I probably could locate one of my old catalogs to find the specs, if you'd like. -Mac |
| Author: | slantzilla [ Sun Nov 20, 2005 5:24 am ] |
I had an old Racer Brown in my first good Slant. It was a little one, but made excellent low and mid-range power. Had a Comp Extreme Energy in motor #2. Made good mid-range and top end power. Had a bigger Clifford in this year. Loved nitrous. Had a Mopar Performance 528 in the first motor. Made excellent power (was my fastest all motor passes) but ate the oil pump gear and welded the motor. |
| Author: | Charrlie_S [ Sun Nov 20, 2005 6:26 am ] |
Quote: I had an old Racer Brown in my first good Slant. It was a little one, but made excellent low and mid-range power.
Is that the cam you sold me? I'm still running it in my 66Cuda, err, was til I ate a couple of pistons.
| Author: | Ron Parker [ Sun Nov 20, 2005 5:50 pm ] |
Hey yall racers see what has come up on camshafts. See Racing Q@ A and get your motor running. Thanks Possum Hey Has That Thing Got A Bagel Bamboozler In It |
| Author: | Will [ Sun Nov 20, 2005 6:01 pm ] |
Racer Brown is the way to go in a solid lift cam. Great power -no problems. Will |
| Author: | slantzilla [ Sun Nov 20, 2005 7:39 pm ] |
Quote: Quote: I had an old Racer Brown in my first good Slant. It was a little one, but made excellent low and mid-range power.
Is that the cam you sold me? I'm still running it in my 66Cuda, err, was til I ate a couple of pistons.: |
