| Need rear end and have questions about swap https://slantsix.org/forum/viewtopic.php?t=15074 |
| Author: | tim/slant man [ Sat Nov 19, 2005 3:07 pm ] |
| Post subject: | Need rear end and have questions about swap |
I have a 318 cu in 77 Volare which needs a spider gear. I have located a 5th Avenue and a Lebaron with 7 1/4 rearends. Will they directly swap out or would it be better to just replace the spider gear only? |
| Author: | Greg Ondayko [ Sat Nov 19, 2005 3:16 pm ] |
They will be a direct swap. - The gear ratios might be different than what you currently have, but otherwise than that they bolt right in. Greg |
| Author: | DusterIdiot [ Sun Nov 20, 2005 5:15 pm ] |
| Post subject: | Don't forget... |
When you swap the rear, grab the speedo gear out of the donor car's tranny (especially if you the rear ratio changes....) -D.idiot |
