Power steering and other stuff
https://slantsix.org/forum/viewtopic.php?t=15096
Author:  valiant effort [ Sun Nov 20, 2005 6:01 pm ]
Post subject:  Power steering and other stuff
I have a 1964 valiant, automatic. I am getting ready to replace my 170 with a 80's 225. While I am doing this i am upgrading to the super six package and also am interested in switching to power steering. What pitfalls, if any, can i look forward to in the conversion and what donor cars would have the appropriate set-up for the conversion to power steering. Also while i have the engine out I am going to replace a lot of the front suspension as well as shocks. Any suggestions? I would appreciate any comments and advice...thanks so much...Mark
Author:  SlantSixDan [ Sun Nov 20, 2005 6:26 pm ]
When you put in the later engine, you need to use a 1/8" annular adaptor ring between the newer engine and the older trans. Pat Blais has the ring you need, and it is a low-cost item. tflitepatty@verizon.net .
Are ya *sure* you want power steering? How come? A '64 Valiant isn't a heavy car; under normal circumstances P/S generally isn't necessary. If it's to cure the slow steering ratio (too many turns from full left to full right), then there are easier and more satisfactory ways of doing it. Power steering makes it easier to turn the steering wheel, it's true, but it also adds a lot of weight to the front of the car, a lot of leak points that like to leak, takes up more space under the hood and the belt/pump bracket is a pain, and sharply reduces road feel unless you spend the big bucks for a custom steering box. What're your thoughts here?
Author:  valiant effort [ Sun Nov 20, 2005 7:17 pm ]
Post subject:  power steering
actually after reading the comments when i did a search on the power steering ive decided against it. I will either buy or rebuild my existing manual unit...thanks for the info on the adaptor..I will order it today..
Author:  SlantSixDan [ Sun Nov 20, 2005 7:24 pm ]
Don't know if you saw this thread, but it's got a lot of comments on the matter. I love the 20:1 manual in my '62.
Author:  valiant effort [ Tue Nov 22, 2005 9:23 pm ]
Post subject:  Steering
Dan,
What ratio do i have now..i believe everything is original on this 64 valiant 170...would i buy a new box or just rebuild this one and change the gears to 20:1
Author:  SlantSixDan [ Wed Nov 23, 2005 7:51 am ]
Stock ratio is 24:1, giving 5-3/4 turns lock-to-lock.
You can buy a rebuilt box with 20:1, or buy the 20:1 worm and ball nut assembly and build up your own (the one in your car or another). It depends on your budget, skill and patience!
Author:  valiant effort [ Wed Nov 23, 2005 11:45 am ]
Post subject:  steering
Dan,
The budget is not as big a deal to me as the skills and patience part *L..sooo i think i will buy a rebuilt one..know of a good resource?..thanks Mark
Author:  Pierre [ Wed Nov 23, 2005 12:04 pm ]
www.firmfeel.com has 24:1, 20:1, and 16:1 rebuilt manual boxes for 275, 375, 475 respectively.
These people rebuild boxes too but I haven't seen a website for them, not sure of their prices.
Steer & Gear
1000 Barnett Road
Columbus, OH 43227
(800) 253-4327
Author:  SlantSixDan [ Wed Nov 23, 2005 12:15 pm ]
Well, lessee here.
Firm Feel says you'll spend $375 for a rebuilt 20:1 box from them.
Steer & Gear says "Call for a Quote" on the 20:1 box.
Both are reputable outfits that've been around a fair long time, so you'd probably do fine to shop by price.
Author:  SlantSixDan [ Wed Nov 23, 2005 12:16 pm ]
Steer & Gear
www.steerandgear.com
