| Gas Tank Vent Tube https://slantsix.org/forum/viewtopic.php?t=15106 |
| Author: | DAJUJ [ Mon Nov 21, 2005 9:05 am ] |
| Post subject: | Gas Tank Vent Tube |
What size, outside diameter is the filler vent tube for the gas tank in my 63 Valiant. PO decided he didn't want it, but I sure do. Can't seem to locate one locally so I think I will make my own. |
| Author: | SlantSixDan [ Mon Nov 21, 2005 10:03 am ] |
Should be able to bend-up your own out of steel brake line tubing. Pretty sure it's 1/4", but it could be 5/16". Make sure to follow the factory routing (out from the boot in the trunk floor, zagging steeply upwards along the left rear wheelwell, making a fairly tight U-turn and then back down along the wheelwell over to the fitting at the outboard end of the filler pipe). |
| Author: | DAJUJ [ Mon Nov 21, 2005 10:37 am ] |
| Post subject: | Vent tube |
Did they design it that way to keep you from pouring gas all over the top of your tank if you screwed up refilling? Thanks for the help. |
| Author: | SlantSixDan [ Mon Nov 21, 2005 10:42 am ] |
Mainly to prevent a siphon effect. |
| Author: | relic-lover [ Mon Nov 21, 2005 8:08 pm ] |
| Post subject: | smaller |
5/16 is the main fuel line size. On the non-emission setup the vent tube is much smaller than the main fuel line BYB - (to the garage with the calipers ....) The vent line measures 1/4 inch OD |
