It is currently Mon Nov 23, 2026 8:19 am
Can you burn rubber with
Poll ended at Fri Dec 09, 2005 2:34 pm
1bbl stock 45%  45%  [ 13 ]
Just some exhaust improvements 3%  3%  [ 1 ]
Headers 3%  3%  [ 1 ]
Turbocharger 0%  0%  [ 0 ]
2bbl/4bbl 14%  14%  [ 4 ]
fuel injection 0%  0%  [ 0 ]
More cam 0%  0%  [ 0 ]
minor head work 0%  0%  [ 0 ]
major engine work 7%  7%  [ 2 ]
Don't know, haven't been able to do it........... 28%  28%  [ 8 ]
Total votes: 29
 Post subject: Burning rubber
PostPosted: Wed Nov 09, 2005 2:34 pm
What does it take to burn rubber?????
(Just thinking an automatic, since a clutch is easy to dump)
PostPosted: Wed Nov 09, 2005 2:42 pm
Car Model: '23 T-bucket
Install a line lock in the front brakes, and you can burn all the rubber you want.
Roger
PostPosted: Wed Nov 09, 2005 3:12 pm
Aw, heck, you don't need a line lock. All you need to burn rubber is a match.
PostPosted: Wed Nov 09, 2005 3:23 pm
Stock 77 aspen wagon was my first burnout machine...
2bbl, 904/3.21 sure grip
PostPosted: Wed Nov 09, 2005 3:45 pm
a 73 duster that's be lightened by rust --------1 bbl a/t tranny would smokim' at will from a stop-- of course these were 75 series 14" tires
 Post subject: Burning Rubber?
PostPosted: Wed Nov 09, 2005 4:19 pm
Heck, I thought the whole idea was to go as quick and as fast as possible WITHOUT burning rubber...
'sides that stuff's expensive.
Steve
PostPosted: Wed Nov 09, 2005 4:39 pm
But it´s fun...
Get jetzon tires, they smoke after 1/2 a turn, and wear like iron, but they drive like it too :roll:
PostPosted: Wed Nov 09, 2005 5:49 pm
Car Model: 69 Valiant 225, 70 with a 265, 70 with a 318
My very tired '69 2 barrel 225 (all stock) can easily burn both tires with a bit of help from the brake pedal.
Richard (aka Fingers)
PostPosted: Thu Nov 10, 2005 7:13 am
My Duster won't spin the tires in a straight line but jerk the wheel real hard and it will sit there and smoke em'.
2.76 gears really take a bite out of the burnout ability.
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Thu Nov 10, 2005 4:14 pm
with the old 2.76 I could smoke the passenger tire but not with the suregrip in either the 3.23 or 3.91. I am also running 235/60R14's, it takes a lot of power to spin 2 of them at once.
PostPosted: Fri Nov 11, 2005 2:00 pm
Car Model: Valiant V200 225 4dr three on the tree
Remember the early 80's, when I and my friend in his Dart -69 made some fireburnouts and a couple of days later found a leak from the petroltank. Could had been a heck of a fireburnout.
Lasse
Signet -66 225
Holley 600 Offy-5270 Dutra Dual,regrind. cam 272 0,420 110, head shaved 0.100 slight.ported
MSD6A
A904
7 1/4 3.23
PostPosted: Fri Nov 11, 2005 3:18 pm
Neutral drops (rev engine in neutral, drop it into first) burn rubber, and trannies too.
PostPosted: Mon Nov 14, 2005 8:26 pm
My 80 aspen finally learned how to smoke them (that's right, both tires) in the burn out box.
Here is a list of modifications, and it took every one before it would do it.
2bbl carb tuned to dump plenty of fuel on demand.
2 1/4 exhaust,
mild head port,
advanced the stock cam just a couple degrees (gives it better low end grunt),
2.94 sure grip rear end,
super short 195-60-15 rear tires,
I can't believe that Phil can't smoke with 3.91 gears ?? Even on wet pavement Phil? I know you've got lots more horsepower than me?
I'd say that rear end gears or a well selected high stall racing torque converter would get you a smoking machine in one easy shot. Cost, about $450. (plus installation)
Smoking out the parking lot at the local car hop..... priceless.
1980 Aspen 225 super six
PostPosted: Sun Nov 20, 2005 11:40 pm
The 3.23 rear gear certainly helps, 2.76 is way too tall IMHO. I have driven 225's with 2.92 gears and that is as tall as I would want as the first gear ratio gets too much.
PostPosted: Thu Nov 24, 2005 4:31 pm
there is no problem to get 100 feet
of rubber with 4.56 gears.
and 150 shot of NOS !!!!
but the down side .........tires!!
