It is currently Fri May 08, 2026 5:07 pm
 Post subject: Calling Dennis
PostPosted: Sat Nov 26, 2005 2:46 pm
Say, Dennis, you said that you had a trick for bleeding the newer master cylinders with the aluminum bodies and plastic reservoirs? I am at my wit's end trying to get a hard petal, and I am willing to try anything right now.
Thanks,
PostPosted: Sat Nov 26, 2005 3:35 pm
Me, Dennis, or the real Dennis (Slantzilla)? :lol:
Well, I do have a bit of advice: The little diaphragm under the caps is quite small on the plastic reservoir - that's what makes up for the fluid loss during normal wear or bleeding brakes... If you seal them after you fill, then bleed, you can create a vacuum inside the master cylinder. at that point, air can suck into the (drum) wheel cylinders and you just keep bleeding them, pulling your hair and swearing - you KNOW how I know! So put the caps on when bleeding to keep fluid from splashing everywhere, but leave them loose!
D/W
P. S. , the calipers are installed bleeder screw up, right?
If it ain't broke, fix it!
Users browsing this forum: Bing [Bot] and 13 guests
