It is currently Mon Nov 23, 2026 12:26 pm
PostPosted: Fri Nov 25, 2005 1:34 pm
My electronic ignition kit from my friends on Ebay arrived without instructions. It all looks pretty simple, except for three wires.
Where does the blue striped w/yellow wire go?
Where does the green striped w/ red wire go?
Where does the black striped w/ yellow go?
Thanks very much and hope you all had a great T' giving,
Joe
Joe Hoppe
PostPosted: Fri Nov 25, 2005 4:44 pm
The black w/yellow tracer goes to the negitive post of the coil, the blue w/yellow tracer goes to the run side of the ballast resister. Green w/red tracer is not used. Just cut and cover it with tape. This is assuming your using this with a single ballast resister, not the dual resister. Yes, you can use a 5 pin ECU with a single resister.
PostPosted: Sun Nov 27, 2005 8:52 am
Thanks, Eric. We'll see how that works.
Joe
Joe Hoppe
