It is currently Mon Nov 23, 2026 12:21 pm
 Post subject: rings?
PostPosted: Thu Nov 24, 2005 9:33 pm
ok 1974 dart 225 stock
cleaned up valve cover, all new grommets, pcv valve, and cracnkcase breather (eledbrock push in from advance)
after a trip i popped the hood and i have oil coming from the breather (crankcase, not from the grommet, the little holes underneath, like oil soaked filter)
i converted to synthethic and i now have a head gasket leak, but an comtinuing to drive it till i get an off day or two)
do i have shot rings causing the extreme blow-by or is this contributed by the head leak?
help appreciated, dustin
PostPosted: Fri Nov 25, 2005 3:16 am
If you've got a blown head gasket it could be pressurizing the crankcase and blowing oil out the breather.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sun Nov 27, 2005 11:30 am
thanks for the feedback...didnt know what i have....i will pull the head and see what i have.....how can i tell if i have shot rings....any tips and tricks
PostPosted: Sun Nov 27, 2005 12:37 pm
Easy test for rings - run a compression check on each cylinder, then squirt some heavy oil into each cylinder and run check again - if compression jumps up then its likely rings.
PostPosted: Sun Nov 27, 2005 12:40 pm
thanks buddy
Users browsing this forum: Amazon [Bot], Craig Hodge and 2 guests
