Calling Dennis
https://slantsix.org/forum/viewtopic.php?t=15161
Page 1 of 1
Author:  gmader [ Sat Nov 26, 2005 2:46 pm ]
Post subject:  Calling Dennis
Say, Dennis, you said that you had a trick for bleeding the newer master cylinders with the aluminum bodies and plastic reservoirs? I am at my wit's end trying to get a hard petal, and I am willing to try anything right now.
Author:  Dennis Weaver [ Sat Nov 26, 2005 3:35 pm ]
Me, Dennis, or the real Dennis (Slantzilla)? :lol:
Well, I do have a bit of advice: The little diaphragm under the caps is quite small on the plastic reservoir - that's what makes up for the fluid loss during normal wear or bleeding brakes... If you seal them after you fill, then bleed, you can create a vacuum inside the master cylinder. at that point, air can suck into the (drum) wheel cylinders and you just keep bleeding them, pulling your hair and swearing - you KNOW how I know! So put the caps on when bleeding to keep fluid from splashing everywhere, but leave them loose!
D/W
P. S. , the calipers are installed bleeder screw up, right?
