It is currently Mon Nov 23, 2026 10:45 pm
 Post subject: engine rebuild (maybe?)
PostPosted: Mon Nov 28, 2005 4:42 pm
Originally I was just going to refurbish the heads on my '66 have them milled a hair, and then install with new gaskets (since head gasket was leaking, but no loss of compression).
However,
I took the heads off, I noticed a couple of my cylinders were wet, and showed LOts of carbon buildup (no coke, just black carbon hardened soot).
My rings might be a tad loose as well (just allowing blow-by) Since the head is already off, is now a good time for a quick rebuild? and if I do rebuild, what new parts are a must and what parts can be re-used provided the wear is nominal?
Caesar
Also what tools to check wear and clearance? feeler gauges i have, but what else.?
PostPosted: Tue Nov 29, 2005 2:35 am
How big is the ring ridge at the top of the cylinder? Is there a double ridge in any of the bores?
Measure the bore wear to decide if you can get away with a basic re-ring job instead of reboring the cylinders.
PostPosted: Tue Nov 29, 2005 7:07 am
The least I've ever done, while having the engine out and apart, was to hone the cylinders, put in new rings, give it fresh bearings, and have a valve job done. That was on a Chevrolet 230 inline six. It had just started to smoke a bit. That little bit of work let it run happily several more years, before I sold it for a profit.
PostPosted: Tue Nov 29, 2005 7:55 am
If you are checking the cylinders' bore diameters, make sure you check several different directions to determine if they have worn in an oblong (oval) shape.
Jerry
