slant six stumble
https://slantsix.org/forum/viewtopic.php?t=15221
Author:  spamman450 [ Wed Nov 30, 2005 4:47 pm ]
Post subject:  slant six stumble
my slant six stubles a little when its idleing. the whole engine shakes slightly because of this. it has a new fuel pump and the timing is set right. the only thing i could think of is that i dont have the carb tuned right(its been rebuilt) or that my plug wires are bad. the wires i am using are of a 318 that i derbied. the wires got pretty hot during the derby but do not show any signs of melting. any ideas?
Author:  Slanted Opinion [ Thu Dec 01, 2005 7:14 pm ]
Many possibilities, but I would first check for vaccumn leaks around carb and intake (and associated vac lines).
-Mac
Author:  junkmailforblankets [ Fri Dec 02, 2005 1:16 pm ]
I second Mac on this one. I had the same problems, noticed a leak, replaced the intake gasket, and all the associated problems disappeared.
Author:  Slant6Ram [ Fri Dec 02, 2005 8:09 pm ]
Post subject:  Checks
After vacuum leaks, check the valve adjustment.
Next time you pull the spark plugs, look to see if one is more crud covered than the rest. If you find a really off looking plug, the wire is likely to be bad.
