| Flywheel https://slantsix.org/forum/viewtopic.php?t=15291 |
| Author: | dart4life [ Tue Dec 06, 2005 2:34 pm ] |
| Post subject: | Flywheel |
Does anyone make new flywheels for our slants? I have a 23 spline a833 o.d(73 dart sport) and I need a flywheel what can I use? thanks |
| Author: | mcnoople [ Tue Dec 06, 2005 2:54 pm ] |
I think mcleod was going to make a run of performance flywheels. Ask 64dartgt he'll know if they do. What is the intended use stock replacement or race use? |
| Author: | dart4life [ Tue Dec 06, 2005 11:03 pm ] |
Its needs to be able to handle 250 h.p(on a daily basis) and a shot of the gas every now and then! thanks |
| Author: | Charrlie_S [ Wed Dec 07, 2005 6:07 am ] |
| Post subject: | Re: Flywheel |
Quote: Does anyone make new flywheels for our slants? I have a 23 spline a833 o.d(73 dart sport) and I need a flywheel what can I use?
Remember, the flywheels are different, between the 67 and older and the 68 and newer. The center hole is larger in the later flywheel. You need the correct one to match the crankshaft.
thanks |
| Author: | dart4life [ Wed Dec 07, 2005 1:50 pm ] |
I remember,and thanks for the info! Which flywheel is the best,as far as strength goes? I did check mcleoud,they have one but dont give any specs on it,and its 300 $$$ thanks for the ideas,keep em comming |
