It is currently Wed Jun 10, 2026 9:05 am
 Post subject: offy manifold
PostPosted: Thu Dec 08, 2005 6:35 am
if i go with the offy what is the best carberator to go on it. i would like to go with edelbrock but i would also like a big 2 barrel or a small 4 barrel. im going to port the heads and all but i wont be rebuilding for a while because of lack of funds haha
thanks guys...dustin
PostPosted: Thu Dec 08, 2005 6:37 am
also i would rather not use a adapter plate if at all possible...i dont know alot about bigger carbs and mounting flanges and all that...all i have had is my adapter 2 to 1 and my bbd
PostPosted: Thu Dec 08, 2005 11:31 am
search this site lots of info on 4 barrel carbs and lots on 2 bbls, if you want to run two barrel i might suggest just a stock super six manifold than the offy. But for the offy you need an adapter plate and the most common four barrel appears to be a 390 cfm unit. Search function lots of info.
PostPosted: Thu Dec 08, 2005 1:43 pm
alot of people use the edlebrock 500 also, as well as the 390
Cuda Progress :D
The dart as it sits now :(
Users browsing this forum: Amazon [Bot] and 5 guests
