Slant Six Forum https://slantsix.org/forum/ |
Radiator Project. https://slantsix.org/forum/viewtopic.php?t=15344 |
Author: | Avenger2040 [ Sat Dec 10, 2005 8:46 pm ] |
Post subject: | Radiator Project. |
I was looking at my father´s Concorde 2001 engine bay, and then a crazy idea came to me. How will my Duster look with a Concorde radiator, fans and coolant deposit? So I was also thinking in how much difficult could that be, anyone knows is my idea is possible? |
Author: | kesteb [ Sun Dec 11, 2005 3:17 pm ] |
Post subject: | |
Anything is possible with a hot wrench and a BFH. Larger radiators are readily available for your car, why use the other? |
Author: | mopar546 [ Mon Dec 12, 2005 2:01 pm ] |
Post subject: | |
you can use a radiator from just about anything if your willing to fab. some brackets. |
Author: | Avenger2040 [ Mon Dec 12, 2005 8:26 pm ] |
Post subject: | |
Ok, but new radiators don´t have filling neck, you need to fill them by cooler bottle, so how dou you connect the bottle to radiator? |
Author: | Avenger2040 [ Wed Dec 14, 2005 8:36 am ] |
Post subject: | |
Ok, I guees new radiators got plugs for cooler bottle then. |
Author: | kesteb [ Sun Dec 18, 2005 5:16 pm ] |
Post subject: | |
When I upgraded the radiator in my '65 Dart. I used a HD radiator from a '77 Aspen with A/C and \6. This radiator only needed the bottom mounting holes redrilled. It should bolt-in on your Duster. Here is a write up I did on the setup: http://www.kesteb.us/slant6/radiator.html |
Author: | dart63 [ Mon Dec 19, 2005 3:59 pm ] |
Post subject: | |
Quote: Ok, but new radiators don´t have filling neck, you need to fill them by cooler bottle, so how dou you connect the bottle to radiator?
The bottle connects to a hose at the base of the radiator cap, over flow goes into the bottle, and when needed fluids from the bottle are sucked back into the radiator and cooling system through the same hose. I have added bottle systems to all of my slants since I have dogs around my property that I care about and they love antifreeze for some reason. I simply cut the line that leads down the side of the radiator to the ground, and send it to the overflow bottle. |
Author: | Avenger2040 [ Mon Dec 19, 2005 8:42 pm ] |
Post subject: | |
Hey dart63, got some pics of your radiator and bottle system? the bottle I got here got two ways for hoses, one is located at the upper left side and the other is at the left back part, this one is bigger than firts one. |
Page 1 of 1 | All times are UTC-08:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
