It is currently Sat Jun 20, 2026 1:22 pm
PostPosted: Mon Dec 12, 2005 5:08 am
I would think it would help the fuel flash better if there was a heater attached to the bottom of the Offy or Clifford manifolds in a setup that uses headers. A machined piece where engine coolant is circulated through it. Has anyone made such a thing or know where to get one?
bwhitejr
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
PostPosted: Mon Dec 12, 2005 7:03 am
I came across this guy's piece, that does just that, about a week ago.
http://www.mergetel.com/~fraso/RasoEnte ... -Mopar.htm
the part is about 2/3 of the way down the page, named "intake manifold heater kit"
I think you are looking for one of these:
You can find it on my products page.
 Post subject: Clifford and frank
PostPosted: Mon Dec 12, 2005 7:06 am
Clifford has a water heated manifold already cast (seen 'em)...
Frank Raso did a really good job on his heater box.
Since I have a "lot" of manifold, I use an exhaust heat box.
(immediate heat, vs. heat about 5-10 minutes after your choke's pulled off).
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 1 guest
