| changing plugs https://slantsix.org/forum/viewtopic.php?t=15465 |
| Author: | JoseyWales [ Wed Dec 21, 2005 6:20 pm ] |
| Post subject: | changing plugs |
I just started tinkering with the slant six in my 65 Dart. I was going to give it a tune up today, but need some advice. Whats the best way to change the plugs, do you have to pull the sleeve out? If so whats the best way to get them out and are they reusable or do I need new ones? This is probably a dumb question but I am new to my slant and want to do it right. Thanks any help would be appreciated. |
| Author: | emsvitil [ Wed Dec 21, 2005 6:26 pm ] |
The sleeves are reusable, they pull right out and may just come out with spark plug, but usually stay in place. With no plug, pull with fingers. They tend to accumulate crud, so you may want to take them out to clean them, which means you may need new rubber seals for them You need to remove the gasket on the spark plugs The spark plug recommendation is an autolite 985 with extended tip, there's also a ngk that's similiar (don't know number) |
| Author: | JoseyWales [ Wed Dec 21, 2005 6:35 pm ] |
It appears as though the sleeve is covering the shoulder of the spark plugs, unless they are just full of crud. I put the socket down in there and it wont bite on anything. |
| Author: | Dustenn89 [ Wed Dec 21, 2005 6:43 pm ] |
have you ever changed a spark plug? do you have the right size socket? |
| Author: | emsvitil [ Wed Dec 21, 2005 6:53 pm ] |
Should be a 13/16 spark plug socket. The plug holds the sleeve in place That would be a lot of crud |
| Author: | JoseyWales [ Wed Dec 21, 2005 7:15 pm ] |
I will blow it out with my air gun tomorrow and try again. I guess Dustenn89 has never asked a single ? in his entire life. Thanks |
| Author: | Dustenn89 [ Wed Dec 21, 2005 7:22 pm ] |
trust me i get hammered every time i ask a question just felt good to be on the other side of it sorry...someone else woulda if i didnt all in good fun |
| Author: | emsvitil [ Wed Dec 21, 2005 7:25 pm ] |
Quote: trust me
i get hammered every time i ask a question just felt good to be on the other side of it sorry...someone else woulda if i didnt all in good fun You don't hammer the new guy right away............. Wait awhile, let 'em get comfortable, then when they drop their guard........... you hammer them. |
| Author: | Dustenn89 [ Wed Dec 21, 2005 7:26 pm ] |
i see i stand corrected...sorry new guy ill getcha later |
| Author: | sick6 [ Wed Dec 21, 2005 7:28 pm ] |
the outlaw josey whales makes an appearance. I love it. remember to put out the stoogie before you change them plugs. |
| Author: | Pierre [ Wed Dec 21, 2005 9:48 pm ] |
Spark plug sockets sometimes have a rubber boot inside them to hold the plug in place so it doesn't drop when you pull the socket out. Assuming you have the right size socket it just may need a little push so the plug sinks into the rubber grommet on the inside. |
| Author: | JoseyWales [ Sat Dec 31, 2005 10:12 am ] |
All in good fun. I finally got er done though. Whoever had this thing before me needs to get a clue. The tubes were filled with silicone, the orange gasket maker stuff. It took some diggin with a pick, but I got em changed. Thanks for the heck and the help. |
| Author: | Rust collector [ Sat Dec 31, 2005 10:25 am ] |
| Author: | SlantSixDan [ Sat Dec 31, 2005 10:43 am ] |
Quote: All in good fun. I finally got er done though. Whoever had this thing before me needs to get a clue. The tubes were filled with silicone, the orange gasket maker stuff.
![]() It's amazing how well a car can carry on running even when subjected to abuse. |
