It is currently Wed Nov 18, 2026 2:29 am
PostPosted: Mon Feb 06, 2006 4:47 pm
I tinkered out in the shop today with the acc. pump linkage for a holley 1945 (piece with U in it) and I fashioned one that could be easily unhooked and slid into a different pump actuating slot. My question is, will this give me a better/quicker pump shot by moving the linkage to the shortest slot? I really don't care about mileage, I just want a fatter pump shot to cover the lean spot before the power circuit kicks in.
Will I have to do all the measuring and adjusting when I'm done too?
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Mon Feb 06, 2006 4:54 pm
I tried all the different slots on mine and didn't notice an appreciable difference. Of course I also discovered some p-valve issues once I actualy tore into it, so my experience may be moot.
PostPosted: Tue Feb 07, 2006 1:52 pm
If you pull the accelerator pump there is an adjustment on the shaft made by a clip that corresponds with the linkage slot you use. I can't remember which goes with which.
aed
/6>V8
PostPosted: Tue Feb 07, 2006 6:31 pm
So the shortest slot is the "quickest" one?
82 D150-225/727
PostPosted: Sun Feb 12, 2006 12:51 pm
Jeb, I didn't play with mine so I couldn't say. I just set it where the old one was when I re-built it.
It seems to me that the set-up with the longest stroke for the pump would produce more jump.
aed
/6>V8
PostPosted: Sun Feb 12, 2006 1:02 pm
Which would be the inside (shortest hole).
It's basically a rocker arm. With the linkage to the throttle, the hole (wherever it is) moves a constant vertical amount. When you're on the inside hole, the arm moves thru a greater angle for a given amount of 'hole' travel. Thus the other end of the arm moves farther when you're on the inside hole.
Users browsing this forum: Google [Bot] and 8 guests
