Slant Six Forum https://slantsix.org/forum/ |
Wierd acceleration Issue. https://slantsix.org/forum/viewtopic.php?t=15487 |
Author: | LASwinger70 [ Fri Dec 23, 2005 12:47 pm ] |
Post subject: | Wierd acceleration Issue. |
Occaisionaly, usually after a long time in traffic, when I step on the gas my car will not accelerate, it does not stall, it feels like a long long long bog. If I take foot off the gas and flutter the pedal a little it eventually kicks back in and off I go. It only happens when I am reaccelerating from a stop, or on an on ramp. It is very sporadic. I have fuel flow (electric pump), my car does not stall. Just will not accelerate or rev up. Any theories (its is a Weber/Holley 5200 Carb, 904 Automatic Trans, Mallory Ign) Thanks, Tim |
Author: | emsvitil [ Fri Dec 23, 2005 2:33 pm ] |
Post subject: | |
sticky accelerator pump or accelerator pump linkage |
Author: | SlantSixDan [ Fri Dec 23, 2005 2:38 pm ] |
Post subject: | |
Or, because it only happens under heat-soak conditions, I'm guessing the accelerator pump chamber is actually boiling or being syphoned dry. |
Author: | DusterIdiot [ Fri Dec 23, 2005 7:12 pm ] |
Post subject: | Weber... |
Those both sound like a viable solutions to start with first...because of the tilt of the ramp and sudden stop you might check your float level. Usually when you get a bog out like that, it's nice and lean so...you might also see if you have a vacuum leak somewhere too...(rechecked your carb mounting hardware?) good luck, -D.Idiot |
Page 1 of 1 | All times are UTC-08:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
