fan ?
https://slantsix.org/forum/viewtopic.php?t=15491
Page 1 of 2
Author:  Dustenn89 [ Fri Dec 23, 2005 10:20 pm ]
Post subject:  fan ?
http://www.jegs.com/webapp/wcs/stores/s ... &langId=-1
would this work on a slant
dumb question or not
i dont know a thing about fans and patterns
thanks
dustin
Author:  dakight [ Sat Dec 24, 2005 4:13 am ]
I think it will fit the nose of the water pump but is there enough clearance between the engine and the radiator? There is not on my 62 Valiant
Author:  64 Convert [ Sat Dec 24, 2005 5:09 am ]
My '64 doesn't have enough clearance for it.
Author:  Dustenn89 [ Sat Dec 24, 2005 7:26 am ]
74?
Author:  dakight [ Sat Dec 24, 2005 7:33 am ]
Dunno... you'll have to do some measuring.
Author:  Dustenn89 [ Sat Dec 24, 2005 9:26 am ]
i kno
just my engine is out of the car and i was ordering parts
didnt know if any had any idea
is it worth the money or is it just a waste?
Author:  SlantSixDan [ Sat Dec 24, 2005 9:49 am ]
As others have posted, it'll be a no-go in a '65 or earlier A-body plus '66 Valiant/Barracuda, a really tight squeeze in a '66 Dart, and possible with care in many '67-up cars.
There are other clutch fan setups that are thinner overall (Toyota, Mercedes, etc.). And you don't need to buy this setup from MP; it was factory installed on MANY different Mopar models of the '70s and '80s, so is common in wrecking yards.
See threads here and here.
Author:  DusterIdiot [ Sat Dec 24, 2005 10:11 am ]
Post subject:  Yep...
I'd hit up a wrecking yard and look for those nice FMJ body cars that are still plentiful...My duster currently has a fan from an A/C optioned Volare on it and the cluthc went out, I ordered a new one to find that I had to tell them I had a Duster 360 to get the length of the shaft right (for some reason te 225/318 clutch had a 1/2" longer shaft putting the clutch unit 'on' the radiator fins...)
buyer beware,
Author:  slanty6 [ Mon Dec 26, 2005 7:44 pm ]
I know it won't fit my 74, but my 74 is a slant six Satellite where i'll bet yours is an A-body. I'd almost put money on it that it wouldn't fit. Slant six engines are L---O---N---G.
Author:  Eric W [ Mon Dec 26, 2005 8:05 pm ]
Huh? I've got a clutch fan on my '72 Satellite. It came from a M body (think an '80's Fifth Avenue). Bolted right on, no cleanance issues.
Author:  Reed [ Mon Dec 26, 2005 10:48 pm ]
I pulled a clutch fan from some boneyard mopar (I think it was a slant, but could have been a v-8) and it bolted into my 86 slanted van no problem.
Dig around in junkyards and don't pay any more than $15 for a used clutch fan. That $105 price is a huge ripoff for a factory piece.
Author:  kesteb [ Tue Dec 27, 2005 1:19 pm ]
Check the junkyards, some of the mid '70s A-body darts had a nice factory 5 blade steel flex fan. I used a 1 1/2" spacer to mount one into my '65 Dart.
Author:  Dustenn89 [ Tue Dec 27, 2005 10:42 pm ]
flex fans anyone?
Author:  SlantSixDan [ Wed Dec 28, 2005 8:01 am ]
Flex fans can work, but I don't like 'em. Too noisy, and old or defectively-made ones are dangerous. Thread here.
Author:  Jeb [ Sat Dec 31, 2005 8:39 pm ]
Flex fans make your car sound like an airplane. They can also chew a radiator at high RPMS.
Page 1 of 2 All times are UTC-07:00
