It is currently Fri May 15, 2026 3:57 pm
PostPosted: Wed Dec 28, 2005 1:05 pm
Doug,
Where is the majority of cylinder wear found in a 225? I was told in the bottom not the top like other engines. Are there any different traits in the cylinder to piston area compared to other engines?
Phil
PostPosted: Wed Dec 28, 2005 1:14 pm
At the very top of the ring travel.
PostPosted: Wed Dec 28, 2005 1:17 pm
I'm not Doug, but no, the 225 doesn't tend to wear the cylinders differently than any other engine. Most of the wear is at the top, not the bottom.
PostPosted: Thu Dec 29, 2005 5:50 am
Doug,
Phil
Cylinder wear on a Slant is not much different then other engines, most of the wear is at the top of the bore, on the thrust side (cam side) of the cylinder.
A 225 tends to have more top of the bore wear then the smaller 170, just because of the longer stroke puts more side load and piston speed on the cylinder walls.
