static timing - points versus electronic
https://slantsix.org/forum/viewtopic.php?t=15552
Author:  relic-lover [ Thu Dec 29, 2005 12:51 pm ]
Post subject:  static timing - points versus electronic
When my motor was out for rebuild I swapped my point distributor for
a rebuilt electronic and a module (Napa aftermarket for a 86 D150
pickup).
With the engine at TDC and point distributor I used to use a test
light on the negative coil to see when the points were open. I could
just turn the distributor until the test turned off and bolt it down.
That would set the timing to fire at that engine position.
Now with the electronic I am unsure how to tell when the equivalent of
the points close event is happening. Can I just turn the distributor to
line up the reluctor and the metallic looking center of the pick up?
Author:  emsvitil [ Thu Dec 29, 2005 1:05 pm ]
Lining up the reluctor will get it close enough to start, then you can use your timing light.
Author:  VDART [ Fri Dec 30, 2005 4:50 am ]
I've always removed #1 spark plug-(or used a spare plug)-- connect it to the #1 plug wire --turn on ignition key-- ground the electrode on the plug & turn the dist-- until it sparks-- then clamp it down & fire it up!!
