It is currently Sun May 10, 2026 10:07 pm
PostPosted: Wed Jan 04, 2006 4:34 am
I am going looking for a 225 Slant Six block and head to build an all out race engine. Is there a block or head that are the best choice? I am looking for a year model car and model the block or head would be in and the casting numbers to look for. How much could I expect to pay and are they readily available in the junkyard. Help! I am ready to get started right away. :twisted:
bwhitejr
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
PostPosted: Wed Jan 04, 2006 10:45 am
pre-75 years have more plug choices. not much beyond that I can think of in the way of differences
-dave
what part of "illegal" is so confusing???
PostPosted: Wed Jan 04, 2006 11:56 am
http://www.slantsix.org/articles/dutra- ... blocks.htm
http://www.slantsix.org/articles/combus ... hamber.htm
http://www.slantsix.org/articles/parts-matrix/jpg.htm
PostPosted: Wed Jan 04, 2006 12:26 pm
The newer heads without the drool tubes are cast with more material around the ports. This means they can be opened up, or ported, further.
Slant Cecil
 Post subject: It's a 'mix and match'
PostPosted: Wed Jan 04, 2006 12:35 pm
You want a 1968-1974 head if you need plug variety, or a 1975-1980 head if you have the need to 'hog' the thing out...
You will want a pre-1976 block if going forged crank (or need it for a 198 long rod mill)...you can still use a 1976+ cast crank mill for standard overbored buildups, check out the articles posted and you'll have to make some 'guesses and choices' on how you want to build it.
PostPosted: Wed Jan 04, 2006 2:06 pm
slightly off topic, but has anyone actually had a cast crank fail? not just a bearing, but an actual crank?
given the choice I realize forged is the way to go, its what I have myself, I was just curious if someone has actually had one fail, in either daily driven or race application. I'm sure it probably has happened, I just haven't heard of it.
