| slantsix to SB727 trany plate..any sources? https://slantsix.org/forum/viewtopic.php?t=15605 |
| Author: | CrAlt [ Mon Jan 02, 2006 6:26 pm ] |
| Post subject: | slantsix to SB727 trany plate..any sources? |
Hello all. Im working on a 4x4 trail crawler project ramcharger and it has a VERY tired 318 in it now. I have a rebuilt slant as well as a good low milage slant just sitting in my grarage waiting for a project like this. Does anyone know of a source for those adapter plates that let you bolt a 225 to a SB bell? The truck isnt used for towing at all so the 225 would be plenty power i would think..heck i get by now and the 318 is so beat it can hardly hold 65mph. |
| Author: | Reed [ Mon Jan 02, 2006 6:43 pm ] |
www.arengineering.com- $400 for a kit. ![]() There is one on e-bay right now too: http://cgi.ebay.com/ebaymotors/slant-si ... enameZWDVW Better be quick though. Otherwise you are looking for an original set. Search www.sweptline.org, www.vannin.com, and here and .com www.car-part.com might help, and www.wildcatmopars.com might have as et (but cost too much). |
| Author: | CrAlt [ Mon Jan 02, 2006 10:07 pm ] |
wow..400 is kinda costly..thats 4 times what i paid for the whole truck lol ![]() I guess ill just keep my eyes out for a cheap 273/318 or a /6 727 |
| Author: | Reed [ Mon Jan 02, 2006 11:03 pm ] |
I will have a core slant 727 available soon. Yours for shipping. |
| Author: | volaredon [ Tue Jan 03, 2006 6:26 am ] |
Where are you located at?? You said that you may be looking for a replacement 318?? Are you anywhere near Chicago?? If so I can help you. Drop in&drive. (Oh, you may have to swap the oil pan&pickup tube from your present engine, car pans are different... I know you would on a 2WD, might get away with it on a 4WD, different crossmember) |
| Author: | CrAlt [ Tue Jan 03, 2006 8:42 am ] |
volardon: im in connecticut Reed: Thanks but I could only guess as to how much it would cost to shipp a 727 from WV to CT...prob alot Good news is i think i already have a line on a slant 727 and engine still in a truck local here. Now that i think about it getting a whole parts truck is gona be the only way since i need to get the mounts too. |
| Author: | Reed [ Tue Jan 03, 2006 9:42 am ] |
Actually, I am in Washington, not West Virginia. Shipping would be even more! Motor mounts are the only thing you will need to really change, the oil pan from a car will work fine, but you might want the deeper truck/van oil sump for off-roading. Just buy the engine/trans and all mounts form the parts truck. |
| Author: | 68 adventurous [ Tue Jan 10, 2006 5:58 pm ] |
hello i have that plate, but not the crank spacer. let me know if you still need the plate we can work something out |
| Author: | Ethan Frazin [ Fri Jan 20, 2006 3:03 pm ] |
Quote: I will have a core slant 727 available soon. Yours for shipping.
hey Reed, what kind of shifter did that /6-727 trans use? floor, collum, button?
| Author: | Reed [ Fri Jan 20, 2006 3:33 pm ] |
Right now it is installed in a column shift van. I don't really thin it makes a difference as to whaft shift linkage the transission is originally installed with, just so long as whateer it is installed in correctly moes the little arm on the side of the tranny. I am not sure when I will be getting this transmission. It is currently in my brother's van and he is someday going to drop it off at my house so I can rebuild his transmission for him. I am going to just pull it and replace it with a better one, but I just don't know when it will happen. |
| Author: | Ethan Frazin [ Fri Jan 20, 2006 3:52 pm ] |
I was hoping to find a push button 727 for a /6, but I don't know if they even made those. and if I understand correctly, the push button thing is integral to the trans case? |
| Author: | slantzilla [ Fri Jan 20, 2006 11:26 pm ] |
Quote: I was hoping to find a push button 727 for a /6, but I don't know if they even made those. and if I understand correctly, the push button thing is integral to the trans case?
Nope, never made. You'd have to adapt a small block PB 727 with one of Andy's kits. |
| Author: | DionR [ Sun Jan 29, 2006 9:53 pm ] |
Quote: Quote: I was hoping to find a push button 727 for a /6, but I don't know if they even made those. and if I understand correctly, the push button thing is integral to the trans case?
