It is currently Sat Jul 18, 2026 5:44 pm
 Post subject: Engine Rebuild
PostPosted: Thu Jan 05, 2006 12:29 pm
Hi Ya
I'm going to be rebuilding a slant 6 225 block.
Can you give me some tips, tricks and general knowledge of what to watch out for etc.
I am hoping to get a motor in fairly good shape and just replace rings and bearings and seals.
Then swap it into my car.
many thanks
T
'67 Dart 225 Super Six
PostPosted: Thu Jan 05, 2006 1:02 pm
Just pay attention to the basics...
The following can be fairly expensive but if you do it right your /6 will run for a long time.
* Choose a competent machine shop (they will handle the details).
* Have the head surfaced to get the compression ratio up a little. Shoot for about 9:1 for a nice pump gas street motor.
* ALWAYS have the head rebuilt (again, let the machine shop choose new part if required).
* Have the rod bolts replaced.
* Use good gaskets.
* Use a new timing chain, oil pump, balancer, cam and lifters.
* Keep everything squeaky clean during assembly and document all clearances.
* Break it in carefully (2000- 2200 RPM for 30 minutes).
Enjoy. The engine will outlive you !!
Rich Nedbal
 Post subject: Re: Engine Rebuild
PostPosted: Thu Jan 05, 2006 1:06 pm
Hi Ya
T
BTW: Personally I don't recommend just doing rings and bearings. These engines are way to old to get by with just a quick R&B job.
Rich Nedbal
Users browsing this forum: Amazon [Bot], Google [Bot], RumDungeon and 3 guests
