| Found some slant headers at the junkyard. https://slantsix.org/forum/viewtopic.php?t=15659 |
| Author: | GoodysGotaCuda [ Fri Jan 06, 2006 3:01 pm ] |
| Post subject: | Found some slant headers at the junkyard. |
I found these headers at a local junkyard...paid $22 for 'em. I bought them for a buddy that has a slant in his 73 Duster. I pulled them out of a truck, and it had a low mount starter. I think the Duster would have a high mount...is it going to be a lot of work to get them to fit? Are the high and low headers very different? Just curious. Thanks! ![]() ![]()
| Author: | SlantSixDan [ Fri Jan 06, 2006 3:13 pm ] |
I don't think you'll have too much trouble with the high-mount starter location, just going by the pictures you provided. If you do find a clearance problem, a mini starter ('89-'99 5.2 or 5.9 V8 or 3.9 V6 Dodge pickup or fullsize van) may solve the problem without pipe bending being required. You may run into other fitment issues in the car that don't exist in the truck. Steering box, K-frame, etc. At least they're a starting point! I see this is your first post. Welcome onboard. Fasten yer seat belt! And would you mind please downsizing your .sig photo in consideration of those on slow connections? Here y'go:
| Author: | slantzilla [ Fri Jan 06, 2006 8:28 pm ] |
Hi Goody, welcome aboard! There is a very good chance that since they came out of a truck they physically will not clear a Duster chassis, no matter where the starter is. |
| Author: | GoodysGotaCuda [ Fri Jan 06, 2006 10:57 pm ] |
Quote: Hi Goody, welcome aboard!
There is a very good chance that since they came out of a truck they physically will not clear a Duster chassis, no matter where the starter is. on cliffords site, the ones they currently sell dont say if they are for a car or truck..hmmmm. |
| Author: | slantzilla [ Sat Jan 07, 2006 7:35 am ] |
That's because Clifford headers may not fit anything. The ones in my '66 were supposed to fit my Duster. They didn't. I had a set of long tubes that were supposed to fit '67-'76 A body. They didn't. |
| Author: | Dago Red [ Sat Jan 07, 2006 2:22 pm ] |
| Author: | MileHighDart [ Sat Jan 07, 2006 2:57 pm ] |
OMG ! Goody hanging out on the slant 6 board ! Whats the world coming to ? Welcome Goody ! |
| Author: | slantzilla [ Sat Jan 07, 2006 5:32 pm ] |
Quote: Fitting them in an early A means having to possibly shim up the motor mounts, grind off part of the steering box, bend the pitman and idler arms down, and some hammer massage. |
| Author: | GoodysGotaCuda [ Sat Jan 07, 2006 10:32 pm ] |
Quote: Quote:
on cliffords site, the ones they currently sell dont say if they are for a car or truck..hmmmm. Quote: hmmm..im willin to bet they fit a truck well if some modification is necessary im sure the guy i got em for can do it. and for $22 i dont think they can be too far off. thanks for the info guys! |
