It is currently Sun Nov 29, 2026 10:35 am
PostPosted: Tue Jan 10, 2006 7:10 am
I need 3, 14" wheels, 5 on 4" bolt pattern. I have one. I hope someone can help. Thanks
PostPosted: Tue Jan 10, 2006 8:13 am
Try the parts section. You can dumpster dive at a junkyard, but junkyard rims tend to be bent by idiots in forklifts that they use to move cars. All it takes is one flat tire pushed sideways by a forktruck to bend an otherwise good rim. The rims you are after were used up till 76 on drum a-bodies. Good luck
PostPosted: Tue Jan 10, 2006 9:41 pm
What is the width of the one you currently have. The size will be stamped on the inside surface of the rim, usually near the valve stem opening.
PostPosted: Wed Jan 11, 2006 7:29 am
I found the wheels I need, thanks to everyone.............matt
