| 14" wheels for 64 Valiant https://slantsix.org/forum/viewtopic.php?t=15694 |
| Author: | Chewie [ Tue Jan 10, 2006 7:10 am ] |
| Post subject: | 14" wheels for 64 Valiant |
I need 3, 14" wheels, 5 on 4" bolt pattern. I have one. I hope someone can help. Thanks |
| Author: | mcnoople [ Tue Jan 10, 2006 8:13 am ] |
Try the parts section. You can dumpster dive at a junkyard, but junkyard rims tend to be bent by idiots in forklifts that they use to move cars. All it takes is one flat tire pushed sideways by a forktruck to bend an otherwise good rim. The rims you are after were used up till 76 on drum a-bodies. Good luck |
| Author: | Doctor Dodge [ Tue Jan 10, 2006 9:41 pm ] |
What is the width of the one you currently have. The size will be stamped on the inside surface of the rim, usually near the valve stem opening. DD |
| Author: | Chewie [ Wed Jan 11, 2006 7:29 am ] |
I found the wheels I need, thanks to everyone.............matt |
